Crosscut Sled Fence Material
Forum topic by Dchip posted 08-02-2010 05:08 PM 3389 views 0 times favorited 10 replies Add to Favorites Watch
View Dchip's profile
271 posts in 3181 days
08-02-2010 05:08 PM
Topic tags/keywords: jig question sled tablesaw
Most sleds I see have hardwood fences. Wouldn’t these be susceptible to small movements that could throw off square? Does the lengthwise grain orientation remove this risk? I’m thinking of using two pieces laminated 3/4’’ MDF or plywood, as I don’t see the downsides to this. Any input? Thanks.
-- Dan Chiappetta, NYC,
10 replies so far
View PurpLev's profile
8534 posts in 3578 days
#1 posted 08-02-2010 05:17 PM
the fences are usually oriented with the quarter sawn edge on top/bottom which keeps any movement in the up/down plane thus not really throwing off the sled’s left/right setup.
hardwoods are easier to work with, can be smoothed out, and look better. also you can get a beefy hardwood in one piece instead of having to glue up multiple 3/4” sheet material = extra work.
that said – you can use whatever you have at hand and works for you as long as it’s functional it’s all good.
View Mark Shymanski's profile
Mark Shymanski
5621 posts in 3642 days
#2 posted 08-02-2010 08:19 PM
Would mdf wear faster than hardwoods?
View GregP's profile
154 posts in 2806 days
#3 posted 08-02-2010 10:24 PM
My cross cut sled is made out of plywood, I would think MDF would be awfully heavy.
-- Greg P, Washington State,
View gerrym526's profile
274 posts in 3738 days
#4 posted 08-02-2010 11:22 PM
My crosscut slleds (have 3 in different sizes) have 3/4 baltic birch bases, and hardwood (3/4 poplar) front/rear fences. Have never had a problem with wood movement because the fences are fastened to the plywood base with long screws every 3-4 inches.
-- Gerry
View jpc's profile
139 posts in 3110 days
#5 posted 08-03-2010 12:46 AM
i guess by reading some of the above ive been lucky, i grabbed a two by two of poplar 36 inchs long from the big box for mine and have had no problems, now that ive said that watch my next cut be fucked up
View jpc's profile
#6 posted 08-03-2010 12:47 AM
opps sorry for the profanity, thinking out loud as i was typing
View JasonIndy's profile
187 posts in 3364 days
#7 posted 08-03-2010 03:58 AM
View TheGravedigger's profile
963 posts in 3953 days
#8 posted 08-03-2010 05:14 PM
I’ve had good luck with SYP dimensional lumber selected for grain. I think good grain is the most important thing.
-- Robert - Visit my woodworking blog:
#9 posted 08-03-2010 06:11 PM
Thanks all. It seems MDF is out. I’m gonna swing by the big box and look for some 8/4 poplar or red oak. I’ll prob still use an mdf base (unless I can find some real good ply), though I’ll prob use a bit of finish to minimize swelling.
View Bill White's profile
Bill White
4873 posts in 3890 days
#10 posted 08-03-2010 06:54 PM
I use a lot of mdf for jigs, etc. A quick coat of dewaxed shellac keeps the mdf stable, and a touch of fine sanding and waxing keeps ‘em slick.
