Table saw trunnion crack
Forum topic by Gaffneylumber posted 12-04-2016 07:42 PM 1132 views 0 times favorited 17 replies Add to Favorites Watch
View Gaffneylumber's profile
Gaffneylumber
103 posts in 946 days
12-04-2016 07:42 PM
Topic tags/keywords: tool
So I was helping a friend tune up an older blue Jet contractor saw he bought recently off of Craigslist. As we were aligning the blade to the miter slots I noticed that the motor seemed a little unstable. This is before we even loosened the trunnion bracket bolts. I looked around inside with a flashlight and found a crack in the trunnion at the front of the blade. The crack is all the way through and you can pull the pieces of cast iron apart. It is right beside where the tie rod goes through the trunnion. What would have caused this? Has anyone seen this before? What is the best option to repair?
-- Grayson - South Carolina
17 replies so far
View Loren's profile
10477 posts in 3766 days
#1 posted 12-04-2016 08:57 PM
contractor saw trunnions are often pot metal,
but whether they are that or iron, the trunnion
can be welded by a shop that does such work.
As an alternative you may be able to find a
trunnion from a scrapped saw on ebay.
View crank49's profile
crank49
4032 posts in 3089 days
#2 posted 12-04-2016 09:09 PM
If it’s cast iron the best bet may be to braze it. A good welding shop would know.
Gaffneylumber
#3 posted 12-04-2016 09:15 PM
Thanks Loren it may very well be pot metal. What would be your thoughts on using an epoxy like jb weld in the crack? I know that stuff is supposed to be pretty strong and will adhere to metal. I could get complete coverage in the crack with the liquid version. My friend only has $140 in the saw and is trying to get out as cheap as possible.
#4 posted 12-04-2016 09:18 PM
I’ve had mixed results using JBWeld in stress
areas but it may be worth a try, especially
if you can drill and tap a couple of holes
for a steel mending plate somewhere along
the crack.
View knotscott's profile
knotscott
8121 posts in 3493 days
#5 posted 12-04-2016 10:24 PM
The older Jet contractor saws were made by Mao Shan, and were nearly identical to the older Grizzly, General International, Omega, Ohio Forge, King, Bridgewood, PM, and many others. Maybe you can find an old donor saw on CL.
View Carloz's profile
Carloz
1147 posts in 709 days
#6 posted 12-04-2016 10:27 PM
I would not advice anyone using a table saw which was glued together.
At least “your friend” learned what craigslist is.
View splatman's profile
splatman
586 posts in 1517 days
#7 posted 12-04-2016 10:31 PM
Mending plates or, if you could drill thru the entire part, (1.) perpendicular to the crack, apply epoxy, then run a bolt thru the hole and tighten it down good.
Might not need to drill through the entire part; (2.) only drill though one 1/2, and an inch or so with a smaller bit into the other 1/2, then thread the smaller-diameter hole.
Apply epoxy to the crack and the repair hardware to make doubly sure this will not come apart again.
View MrUnix's profile
MrUnix
6887 posts in 2317 days
#8 posted 12-04-2016 10:41 PM
Lots of ways to fix cracked parts pretty easily, but before doing anything, you need to figure out what it’s made out of and go from there. Maybe post a picture or two as well :)
If it’s cast iron… it’s easily welded, which is the preferred method.
View corelz125's profile
corelz125
512 posts in 1094 days
#9 posted 12-04-2016 10:41 PM
It’s not going to be cheap to weld it. Cast iron is tough to weld and some people don’t know how to weld cast. My trunion cracked on my saw when I first brought it home but it was brand new and was covered under the warranty.
MrUnix
#10 posted 12-04-2016 10:53 PM
- corelz125
Hmmm… around here, a welding shop would charge maybe $25 to braze a small crack. Certainly cheaper than trying to source a new bracket for an old machine like that. I’ve even fixed cast iron a few times using standard ER70S wire in a mig welder, which basically cost me nothing but about a half hour of my time. YMMV.
View SignWave's profile
SignWave
440 posts in 3153 days
#11 posted 12-05-2016 02:37 AM
I’ll echo that brazing is the best choice for a crack like you describe. Brazing works best when you have a good size surface that mates together properly, and it sounds like you do. It isn’t all that difficult and should end up at least as strong as the original part, and it will be permanent.
If you use adhesives like epoxy, it will probably fail eventually if it works at all, and it will prevent a proper repair later.
Before I had a welder, I had a couple of small jobs done at a local muffler shop (not a chain). The cash price was very reasonable.
-- Barry, http://BarrysWorkshop.com/
Gaffneylumber
#12 posted 12-05-2016 02:42 AM
Thanks guys for all the insight and advice. If it were my saw I would probably go the welding route but my buddy sent me this pic and said he decided to epoxy it. Thanks Loren and Splatman for the mending plate idea. He said that he will add one for extra support.
View bigJohninvegas's profile
bigJohninvegas
484 posts in 1580 days
#13 posted 12-05-2016 03:07 AM
It s not going to be cheap to weld it.
- corelz125
Hmmm… around here, a welding shop would charge maybe $25 to braze a small crack. Certainly cheaper than trying to source a new bracket for an old machine like that. I ve even fixed cast iron a few times using standard ER70S wire in a mig welder, which basically cost me nothing but about a half hour of my time. YMMV.
- MrUnix
I agree with Brad. $25 at a weld shop for sure. Don’t give up if the JB weld fails.
Scary fix, good luck.
-- John
corelz125
#14 posted 12-05-2016 03:08 AM
There’s a difference between welding and brazing strength.
SignWave
#15 posted 12-05-2016 02:02 PM
Sometimes you have to just choose a path and run with it. I hope it holds well.
