Which plywood blade and TPI
Forum topic by WoodNuts posted 08-02-2010 04:51 PM 1516 views 0 times favorited 6 replies Add to Favorites Watch
View WoodNuts's profile
WoodNuts
74 posts in 3147 days
08-02-2010 04:51 PM
Topic tags/keywords: question tip milling
My plan is to cut full sheetgoods atop a 1” thick insulation foam board, make my mark, set my veritas Power Tool Guide in place and rip it.
http://www.leevalley.com/US/wood/page.aspx?p=41707&cat=1,240,45313&ap=1
Should provide an accurate and clean cut every time. I have a plain PC 7 1/4” and with a 40TPI blade like frued, should yield great results.
I do plan on taking a slight 1/16th initial pass followed by full depth.
Question: What TPI blades are you all using? Is there a significant improvement from the 40 to the 60 TPI, or even 60-80 TPI? Prices are 15/20/50 dollars respectively. Maybe best of both ends from 40-80 would be the 60TPI.
What do you all think?
-- ...there's a fix fer dat...
View Gene Howe's profile
Gene Howe
11062 posts in 3627 days
#1 posted 08-02-2010 05:00 PM
I use a 40 TPI made by Tenryu specifically for plywood. My shop made guide provides zero clearance on the “good” side of the cut. In hardwood plywood, there is no chip out.
IMHO, a 60 TPI is a waste of $. A scoring cut may be a good idea, but I have never found it necessary.
View knotscott's profile
knotscott
8146 posts in 3575 days
#2 posted 08-02-2010 05:32 PM
As important, if not more important than tooth count is the tooth grind. A Hi-ATB grind has the lowest tendencies for tearout. Freud has a new 60T Hi-ATB that should do nicely, but if you’re not up to spending the bucks, their Diablo D0740X (are any quality) 40T ATB should do well too for ~ $15.
View CoolDavion's profile
CoolDavion
436 posts in 4023 days
#3 posted 08-05-2010 07:11 PM
One thing I found that helped me , along with the insulation trick.
I took a roll of the plastic carpet protector, chopped it into roughly 2” rolls. Then I wrapped the line I was going to cut (on both sides) with tape and pressed it down. The tape helped to support the veneer and prevent chipping.
-- Do or do not, there is no try!
Gene Howe
#4 posted 08-06-2010 01:12 AM
CoolDavion,
I understand the tape. But the plastic carpet protector has me baffled. It’s purpose is??
CoolDavion
#5 posted 08-07-2010 04:03 PM
@Gene
I used the carpet protector as “tape”. I tried what I had, masking tape, blue paint tape, some other plastic tape etc., they did not seem to work that well for one reason or another.
I had read/heard about using the carpet protector somewhere, and gave it a try and it worked good.
The thing is to make sure that you press it down to the wood well to give support during the cut.
View Ger21's profile
Ger21
1075 posts in 3330 days
#6 posted 08-07-2010 07:28 PM
Not cheap, but this is what I use on my home built panel saw with a 7-1/4” Dewalt. 60T
http://www.forrestblades.com/hiat.htm
-- Gerry, http://www.thecncwoodworker.com/index.html http://www.jointcam.com
