Miter Fence for Miter Saw
Forum topic by ChemicalMan posted 08-02-2010 03:28 PM 1414 views 0 times favorited 6 replies Add to Favorites Watch
View ChemicalMan's profile
ChemicalMan
2 posts in 2820 days
08-02-2010 03:28 PM
Topic tags/keywords: miter saw question
I am new to woodworking a recently purchased a Craftsman 15 amp 10’’ Sliding Miter Saw. I realized that the left fence was not completely flush with the right fence. I looked at other saws and realized that all of them do this to some degree, but I feel that it was severe on this model.
I can square it up to cut either an inch off the board (board only flush with the left fence) or a foot off the board (flush with both fences), but not for both. Does anyone have any suggestions for modifying the fence OR am I missing something in squaring up the saw? Is there a better model for about the same price ($199).
Thanks.
View richgreer's profile
richgreer
4541 posts in 3040 days
#1 posted 08-02-2010 06:41 PM
IMO – those fences have to be properly aligned. You should not have to cope with them being out of alignment.
Complain and/or get a different saw.
View PurpLev's profile
PurpLev
8534 posts in 3614 days
#2 posted 08-02-2010 06:48 PM
sounds like a defective item – I’d swap it for another if you are planning to keep this model. or look at craigslist for a used higher end model in the same price range.
richgreer
#3 posted 08-02-2010 09:12 PM
If, for some reason, you cannot have the saw fixed and you cannot return it, I offer this suggestion.
I like to attach 3/8” wooden boards to my miter saw fences. I do this primarily to get taller fences. Of course, I have to countersink the screw heads so they don’t interfere.
If the fences were not lined up I would shave just the right amount off of one of the boards so that, after mounting the boards the fence surfaces are perfectly lined up. A drum sander may be the best way to alter the thickness of one board. I think you could also do it with a thickness planer.
ChemicalMan
#4 posted 08-02-2010 09:49 PM
Thanks for your suggestions. I was able to return the saw and may am now looking to purchase a different one.
But I noticed that all the saws at the store did this to some extent. I would line up my square on the left fence and then push it to the right fence, where it would “catch” ever so slightly on more expensive models and a little more on the cheaper models. I don’t know if someone could repeat this on their saw and let me know if I am making a mountain out of a mole hill.
Thanks.
richgreer
#5 posted 08-02-2010 11:51 PM
I get an almost negligible catch on my Makita CSMS. I would say they are out of alignment by less than 1/1000 of an inch.
I have a wood board attached to each fence like I mentioned before and I can’t tell if this is a problem with the tool’s fence or the boards I attached.
View Chriskmb5150's profile
Chriskmb5150
253 posts in 3041 days
#6 posted 08-03-2010 12:51 AM
I have the same saw. what i did was clamp the fence in a sheetmetal brake and heat up the aluminum a bit then let it cool while still clamped. it cooled true.
-- Woodworkers theory of relativity - the quality of your scrap is relative to your skill level
