TS sled when blade is at 45 degrees
Forum topic by Steve K posted 01-12-2008 05:35 PM 1413 views 0 times favorited 5 replies Add to Favorites Watch
View Steve K's profile
Steve K
6 posts in 3661 days
01-12-2008 05:35 PM
Topic tags/keywords: tablesaw jig sled
I have a question about safely making 45 degree edge miters.
I made a small table saw sled for normal crosscutting jobs. Most of my projects are small, and I routed a tee-slot for clamps on the sled, so my fingers stay well away from the blade. The sled has helped my accuracy, and it feels a lot safer.
I’m thinking about making a sled in the same fashion to use when I tilt the blade to 45 degrees to make miters, like when making a box. I have a delta contractors saw, with the blade tilting towards the right. Is there any safety issue in using a sled, when the blade is set to 45 degree angle?
Thanks
-- Steve
5 replies so far
View Betsy's profile
Betsy
3391 posts in 3766 days
#1 posted 01-12-2008 05:52 PM
Steve – I use a TS sled all the time for miter cuts. It’s quite safe. There are a variety of styles of sleds. I use my sled that I also use for general cross cuts. It’s very accurate.
-- "Our past judges our present." JFK - 1962; American Heritage Magazine
View gizmodyne's profile
gizmodyne
1770 posts in 3960 days
#2 posted 01-12-2008 05:54 PM
Just design your sled so that your hands can’t go near the blade. Make it higher where the blade goes up. You can also make a miter sled with the support fences set at 45 so that the blade is straight 90 and the pieces are set. Then you can cut matching miters. I believe this is the preferred method.
Steve K
#3 posted 01-12-2008 06:07 PM
Thanks for the quick replies!
Would you use the single runner design, where the cut-off would fall on the TS table, or the double runner design where the right side of the sled would carry the cut-off past the blade?
I seems like with the blade tilted to 45, there sure is more chance of the cut-off getting trapped when it’s cut.
Steve
-- Steve
View GaryK's profile
GaryK
10262 posts in 3859 days
#4 posted 01-12-2008 06:11 PM
I like to cut with the cutoff under the blade. That way it will always fall away from the blade, and
not land on top of it.
View LONGHAIR's profile
LONGHAIR
94 posts in 3685 days
#5 posted 01-12-2008 06:50 PM
GaryK is quite right about getting rid of the off-cut piece. Even small pieces can be thrown by a spinning blade.
Also (since you mentioned in the original post) the intent of this is precision edge miters, I would rough cut my parts close to size and then cut the miters. You will get a much nicer cut if it is just a light trim. You really don’t want big pieces falling anyway.
I built a rig one time when I needed to cut a lot of little cubes. They were 3/4” basically square, angled on two sides, trapeziods really. I started with 3/4” x 3/4 stock and was cross-cutting the slight angles. I built a small three sided channel, like a gutter I_I, it was 4”-5” wide and about 6” long. I clamped it to the rip fence and used the opposite vertical face as a length stop. This left a 4”-5” wide channel between the blade and that fence. I clipped a small blow gun (air nozzle) to the fence, blowing at the cut-off pieces. Cut them with a cross-cut sled or miter gauge and when they drop, the air blows them out onto the outfeed table. You can cut dozens of parts this way w/o stopping between cuts.
