Small Shop Air Conditioner Size redux
Forum topic by TelescopeMaker posted 08-01-2010 07:31 PM 2754 views 0 times favorited 14 replies Add to Favorites Watch
View TelescopeMaker's profile
TelescopeMaker
73 posts in 2889 days
08-01-2010 07:31 PM
Topic tags/keywords: air conditioning humidity small shop question
I am concerned about rusting my tools and adversely affecting my lumber.
I’m sizing of a window AC unit (thru the wall) for an 11×19 stand-alone shed. It’s got no windows, is partially shaded in the morning, but heavy afternoon sun. Atlanta GA is 80-90 degrees in the summer with 90-60% humidity. It has R13 insulation and rests on a concrete pad.
The air conditioner calculators say that need a 2800BTU AC unit, but they don’t make units that small, so the lowest size is 5000. But they always warn about using oversized units because it may not dehumidify it very well.
I read where people say that the AC will cool it off so fast it won’t have time to de-humify it at the same time. Cool air means it has a chance to condense, and That can be really bad on tools and wood.
How do you handle the humidity for such a small shop or is it going to matter much?
Is 5000 to small? too big? should I opt for 12k btu? Should I look for one that will de-humidfy separately? Any suggestions?
TIA
-Bill
-- Telescope Maker, Woodworker, Brewer, Gizmologist, Gardner, Lawn Mower
14 replies so far
View dmorrison's profile
dmorrison
151 posts in 3131 days
#1 posted 08-01-2010 07:46 PM
They do make 2500BTU air conditioners
http://www.cedarwoodfurniture.com/petcool.html
http://www.eicsolutions.com/2500btu-thermoelectric-air-conditioner.php
But I’m sure they are very expensive since they are specialty units.
Buy the 5000BTU unit and a dehumidifier. That combination should handle the heat and humidity
Dave
View MarkwithaK's profile
MarkwithaK
370 posts in 3047 days
#2 posted 08-02-2010 03:35 AM
I work in HVAC/R and can confirm that too big of a unit will not remove the humidity from the conditioned space. Just makes it cold and wet, this can also lead to mold. With such a small space you’ll have a hard time finding an economical source of cooling.
-- If at first you don't succeed then maybe skydiving isn't for you.
TelescopeMaker
#3 posted 08-02-2010 04:00 AM
Thanks Mark. So what do you think, is a 5000 BTU model too much for a shop that size? Will an extra dehumidifier do the trick? BigBox has has an AC unit for $99. might be worth a shot? or should I get the 6500 BTU model?
MarkwithaK
#4 posted 08-02-2010 04:25 AM
Eh you’re taking a chance either way really. If you look at it this way….2800 btu’s is just less than 1/4 ton of cooling capacity, 6000 is 1/2 ton.
View Vicki's profile
Vicki
1088 posts in 3213 days
#5 posted 08-03-2010 02:29 AM
I don’t know all the math answers, but I have a 12X18 shed on crush r run base with a 5000BTU. I’m on the Eastern Shore of MD. On days when it’s over 90 my little unit can’t keep up. I wish I’d gotten a 6000BTU. My walls and ceiling are insulated.
-- Vicki on the Eastern Shore of MD
TelescopeMaker
#6 posted 08-03-2010 04:50 AM
Thanks Vicki. I got a look at your shop pictures, and it’s about like mine. I have to say, I am envious you got as much in there as you do. Thanks for the tip, I think I will go for the higher BTU model.
When I replaced 3 out of the 4 walls last year, I raised the cieling just like you – vaulted like that, and I love it. It is nice to be able to flip a sheet of ply without taking it outside first. I left room on the floor to put down flooring on sleepers with insulation under them. But one thing at a time ;)
Vicki
#7 posted 08-03-2010 05:13 AM
My ceiling is only about 6 1/2 – 7 ft inside, which works fine for me (5’5”), but when taller men come in they have to duck a bit. A higher ceiling would have been nice for when I make a bookshelf or want to stand boards up, but I guess the lower ceiling makes it cheaper to heat and cool.
TelescopeMaker
#8 posted 08-03-2010 05:18 AM
7’ inside. Ahhhh. Ok, now I know I will be getting the larger size. Thanks a million.
You know it wouldn’t take that much to swap that roof out for a barn like roof… Think of the storage ;)
View abbyandal's profile
abbyandal
3 posts in 2447 days
#9 posted 05-05-2011 06:42 PM
I’m curious about what size you ended up going with? And did you have any luck? For anyone else coming across this problem, there are some good sizing guides here: Portable Air Conditioners
View Bertha's profile
Bertha
13494 posts in 2562 days
#10 posted 05-05-2011 06:55 PM
Why not add a stand-alone dehumidifier. I’ve got a small one in my shop (alongside a 5000 BTU window unit) and I haven’t had rust problems (knock on wood).
View dbhost's profile
dbhost
5686 posts in 3101 days
#11 posted 05-05-2011 07:07 PM
Not sure how relevant this is to you, but…
My shop is a small attached garage, 18’x20’, with 9.5’ ceilings, and an additional 5.5’x2.5’ bump out. I have R30 in the ceiling, R10 with radiant barrier on the 2 overhead doors, R19 on the common wall, and nothing anywhere else…
The calculators say I should use an 11K BTU A/C, I am using a 12.5K BTU unit, and have no problems overcooling the space. My humidity is about the same as yours, but my heat is notably higher.
I have only very recently finalized the permanent installation / sealing of the system, so air infiltration from the outside is no longer a problem, dehumidification of the space is pretty easy…
My A/C unit has options for cool, dehumidify, or fan only.
My neighbors has a similar to yours, but different sized shed shop. 12×16, 8’ ceilings, R30 / radiant barrier in the ceiling and only R10 in the walls (the same foam board rig I use on my garage doors, but on his walls… ) He cools with a cheap Goldstar 5K BTU window unit that he picked up off of a Craigslist curb alert (the original owner bought it undersized, and couldn’t take it back, couldn’t manage to sell it etc…). It works well for him with no humidity / mold issues 5 years now… His A/C unit is MUCH louder than mine, but that’s okay…
I would control the air coming in / going out of the building. You don’t want to end up air conditioning the outside world you know!
For what it’s worth, If I had a stand alone building like his 12×16, or yours, I would look for one of the smaller A/C window units that also does heat to knock out 2 problems at once…
-- My workshop blog can be found at http://daves-workshop.blogspot.com, YouTube Channel https://www.youtube.com/channel/UCoa-AgyeFWqnQfGIJwdzkog
Bertha
#12 posted 05-05-2011 07:42 PM
I wish I had opted for the heat pump when I installed my window unit. It was 95F outside when I bought it and heating wasn’t on my mind:)
dbhost
#13 posted 05-05-2011 07:51 PM
You never see heat pumps down here in the Houston area. I have no idea why. I always assumed it had something to do with the humidity…
View ferstler's profile
ferstler
342 posts in 3389 days
#14 posted 05-05-2011 11:58 PM
I have a 6500 btu unit in my 240 square foot shop. It iis mostly in the shade, and has minimal insulation (R5 foam sheets under the roof, with a bit more of that about half way around the shop). I hope to incrementally add insulation as time goes on, having it fully insulated eventually, except for the floor, which is double-layer plywood over a tight crawl space.
In any case, the AC unit works to perfection in there during the hottest and most humid time of year in Tallahassee, which is probably worse than Atlanta. I keep it at 82 degrees when I am not in there (an easy load for the unit), and lower it to 75 when I am working (it runs a lot then, however). So far (two years, with the first year dealing with a shop with no insulation at all), it has had no problems. I also have a separate dehumidifier that I use when it is neither hot nor cold outside, but still humid. I use a space heater in the winter.
Actually, the shop is so small and packed with gear that I do most of my work out on an adjacent deck, but I need the AC and/or dehumidifier in operation when work is not being done, so as to keep the tools from rusting.
Howard Ferstler
