Skil Worm Drive Question
Forum topic by Gene Howe posted 1025 days ago 571 views 0 times favorited 7 replies Add to Favorites Watch
View Gene Howe's profile
Gene Howe
3195 posts in 1597 days
1025 days ago
Hey guys,
Any of ya use the Skil WD? If so, How do you adjust the tightness of the lever that holds the blade depth? Mine only gets tight on the last 1/16 of it’s travel. It used to get tight at about half the full travel.
For some reason, when the blade is exposed about 1/8 to 1/4 the lever won’t tighten at all.
Thanks.
7 replies so far
View Jim K's profile
Jim K
94 posts in 1306 days
#1 posted 1025 days ago
What is the model number ?
I have one i have not had any problems with the model i have.
View childress's profile
childress
835 posts in 1711 days
#2 posted 1025 days ago
You could try to take the nut off that holds the latch or lock down. move the bolt and retighten the nut. it will start to clamp sooner then the last 1/16th inch.
-- Childress Woodworks
View Pete_Jud's profile
Pete_Jud
407 posts in 1922 days
#3 posted 1025 days ago
I have an 20 year old mod 77 worm drive, I have used it and abused it, even cutting cinder blocks with it, with water cooling for the cutoff wheels. I only use it for cutting sheet goods down now or if a friend wants help building a deck or something. I found that I had some rust on the back side of the slider and a few min’s with some 400 grit took care of the problem.
-- Life is to short to own an ugly boat.
Gene Howe
#4 posted 1024 days ago
Thanks guys! that E-clip under the acorn nut seems to be the key.
View scrounger's profile
scrounger
82 posts in 1252 days
#5 posted 1024 days ago
Childress is right Gene. I have used those saws for over 50 years and still love em. It is quite difficult to wear one out.
-- Dave, Southern IL.,
Gene Howe
#6 posted 1022 days ago
Fixed it!
Pulled out the E clip and the acorn nut was then loose enough to adjust.
Thanks everyone.
View F Dudak's profile
F Dudak
342 posts in 1979 days
#7 posted 1022 days ago
Best saws around!!!
-- Fred.... Poconos, PA ---- Chairwright in the making ----
