Problem with finish.
« back to Woodturning forum
Forum topic by Mark posted 12-01-2016 06:08 PM 612 views 0 times favorited 7 replies Add to Favorites Watch
View Mark's profile
Mark
959 posts in 2123 days
12-01-2016 06:08 PM
Morning all. 1st. Please excuse the crummy pics. best I could do on short notice. Pictures are of a Cherry hollow form I’ve just finished. Sanded to 1000 G and 3 coats of DIY WOP (gloss varnish cut 50/50 with thinner. Most of the piece took the finish well as I expected it ,to but right where the little knot is, an inch or so on each side and almost the full length of the piece on the one side, it’s like a sponge when applying the WOP. I’ve applied at least 4 extra coats in this area alone, as well as dabbed it with some of the finish on my finger and it just soaked right in. The inside in this area doesn’t feel wet, so I dunno. I have a can of straight gloss varnish that hasn’t sealed so well and is getting kind thick. I applied a bit last night to the offending area and it’s starting to seal up. I’m thinking’ very porous end grain from the knot???? The wood was a BIT punk in this area. Any thoughts? Whatcha think?
Thank you.
-- Mark
7 replies so far
View Druid's profile
Druid
1867 posts in 2943 days
#1 posted 12-01-2016 08:00 PM
Mark, first thing I’ll say is that this looks like a well crafted piece with interesting character. Based on your comment that it’s starting to seal up, it sounds like you are solving the problem. Otherwise, I would suggest try a Wood Hardener on “softer” areas such as this (before getting to the final finishing) if you have this happen again. Just a thought.
It does look like you’ll have a winner when you are done.
-- John, British Columbia, Canada
View Wildwood's profile
Wildwood
2426 posts in 2283 days
#2 posted 12-01-2016 08:29 PM
I would try 60/40 (60% finish/ 40% solvent-thinner) mix in that area or go full strength with finish in that area.
Whether use a mix or full strength idea is apply light coats getting a build up of finish that area.
Good luck with it!
-- Bill
View OSU55's profile
OSU55
1869 posts in 2138 days
#3 posted 12-01-2016 08:32 PM
Use your 50/50 finish with a brush and soak the soft area and keep at it until it stops. Wet the whole piece down for several minutes, then wipe the finish off. Use straight finish on the soft area if you want. Poly thinned 1:1 is about like Danish oil oil – keep wet for 5-20 minutes, then wipe off.
View RogerM's profile
RogerM
798 posts in 2547 days
#4 posted 12-02-2016 02:13 AM
Seal it up with a coat of Seal Coat (dilute shellac) then put on the poly
-- Roger M, Aiken, SC
View Bob Collins's profile
Bob Collins
2567 posts in 3832 days
#5 posted 12-02-2016 06:49 AM
Your getting good advice with the above Mark, no need for me to confuse you. Nice piece of turning.
-- Bob C, Australia. Your best teacher is your last mistake.
View Woodknack's profile
Woodknack
12369 posts in 2528 days
#6 posted 12-02-2016 08:41 AM
Knots are end grain so they will be more absorbent. In the future apply finish to them with a brush (or dab it on) to seal, sand smooth, then apply your overall finish.
View Mark's profile
Mark
#7 posted 12-02-2016 07:44 PM
Thanks for all the tips gents. I’ll try the 50/50 with a brush first.
-- Mark
