Finish for new cabinet doors?
Forum topic by HickWillis posted 11-30-2016 09:28 PM 655 views 0 times favorited 9 replies Add to Favorites Watch
View HickWillis's profile
HickWillis
114 posts in 781 days
11-30-2016 09:28 PM
I’m about to begin the process of building some cabinet doors for my kitchen. I want them to have a soft sheen (semi-gloss?) and am not sure what to use. I have a lot of doors to finish and will be applying the finish by hand so I’m looking for something that is easy to apply by hand and will provide a durable finish. Any ideas?
-- -Will
9 replies so far
View Logan Windram's profile
Logan Windram
347 posts in 2584 days
#1 posted 11-30-2016 09:35 PM
Wiping Varnish, couldn’t be any easier. Keep adding layers until you like the look.
HickWillis
#2 posted 11-30-2016 09:36 PM
Wiping Varnish, couldn t be any easier. Keep adding layers until you like the look.
- Logan Windram
Like a wipe on poly?
-- -Will
Logan Windram
#3 posted 11-30-2016 09:47 PM
- Logan Windram
- HickWillis
exactly. get some of those cups from Rocker so you can hang the doors for drying, and do nice thin coats and build up a sheen you desire. Note, those rags used will be flammable, don’t leave them bunched up or inside when you are done…
spraying is the way to do it, but wipe on is the next easiest IMO. Bob Flexner has some articles on it is his book, and “m sure one o fthe two woodworking publications.
View Dave G's profile
Dave G
332 posts in 2170 days
#4 posted 12-01-2016 12:27 AM
I just refinished my kitchen cabinets and used Minwax wipe-on poly (satin). I use that stuff anywhere (inside) its going to take a beating. It’s nearly bulletproof and it looks great. You control the depth of finish. Usually 3 coats does it for me. I reuse the applicator rag by putting it in a ziploc in the deep freeze – safe and chemically inactive – between coats.
Pros don’t care for poly because the recoat time means they have to keep coming back. For homeowners, that’s usually not a problem.
If you for some reason don’t like the sheen, you can just go over with a different sheen to finish it off. You can make your own hand wipe by thinning the stuff that comes in a can.
-- Dave, New England - “We are made to persist. that's how we find out who we are.” ― Tobias Wolff
HickWillis
#5 posted 12-01-2016 05:18 PM
Thanks for the tips! I’ll go with a wipe on!
-- -Will
View Carloz's profile
Carloz
1147 posts in 713 days
#6 posted 12-04-2016 06:30 AM
Not necessarily correct.You can usually go duller finish but not shinier.
View DMC1903's profile
DMC1903
285 posts in 2449 days
#7 posted 12-04-2016 06:36 AM
General finish\ Arm-a-Seal is a great product, esay to apply and tough as nails when fully cured
HickWillis
#8 posted 12-05-2016 01:47 PM
Yeah I was looking at General and Waterlox.
-- -Will
View rwe2156's profile
rwe2156
3073 posts in 1603 days
#9 posted 12-05-2016 02:47 PM
Will,
I used satin Polyacrylic on my kitchen. I really liked it….but.
Since its water based, I could sand and put 3 coats on in one day.
Now the “but”: After 7 years, its held up OK although it does seem to be a little subject to staining (stuff like blueberry juice, beet juice, etc). So I think there must be some degree of porosity to the finish.
Semi gloss might be a better choice. If I could do it over, I would buy an HPLV sprayer and use poly.
I would test a couple different finished on the backs of some doors.
