Proper Router Bit Usage
Forum topic by CoolDavion posted 01-12-2008 03:58 AM 2946 views 0 times favorited 13 replies Add to Favorites Watch
View CoolDavion's profile (online now)
CoolDavion
434 posts in 3906 days
01-12-2008 03:58 AM
Topic tags/keywords: question
I was using my router, and I was obviously doing something wrong.
During use I notices smoke, not just wood coming from the bit.
I stopped and looked at the bit. It is all discolored around the bottom (are that was in contact with the wood).
Was I going too fast, too deep?
I would like to learn from my mistakes, so your advice would be greatly apreashiated.
-- Do or do not, there is no try!
13 replies so far
View JasonH's profile
JasonH
136 posts in 3910 days
#1 posted 01-12-2008 04:00 AM
Sounds like you may have been working the bit too hard. Too much of a deep cut. Can you describe exactly what you were doing—bit used, wood type, cut made—at the time of the smoking?
-- Living on the square...
CoolDavion
#2 posted 01-12-2008 04:03 AM
It was a 3/4” straight bit in Memamine. Routing against a fence.
About 3/8” deep. Which I’m thinking was the root of the problem.
JasonH
#3 posted 01-12-2008 04:07 AM
That’s my guess…too deep. In my experience, the synthetic materials have had a tendency to generate a heckuva lot of heat when being cut by rotary tools…
Also, were you going very slowly?
View GaryK's profile
GaryK
10262 posts in 4070 days
#4 posted 01-12-2008 04:23 AM
I would try to take it in muiltple passes also.
CoolDavion
#5 posted 01-12-2008 04:30 AM
Does anybody know of a rule/guide to go by to determin how deep of a pass to make with a perticular type of bit/cut?
GaryK
#6 posted 01-12-2008 04:39 AM
From what I hear you usually take the bit diameter divided by 2 and that the max depth of cut.
That’s just a rule of thumb. The variables are wood type, bit speed (for variable speed routers)
and speed you take your cut.
My rule is that if you feel like you’re fighting with the router you are taking too big a cut. Let the router
do the work.
Hope this helps.
View Joe Lyddon's profile
Joe Lyddon
10205 posts in 4134 days
#7 posted 01-12-2008 06:12 AM
It’s easy to also go TOO SLOW for the cut…
3/8” doesn’t sound really deep to me…
What kind of wood was it?
Try reducing the dept to say 1/4” and during the cut, really push things along a little…
Two bits, the smoke will go away and you’ll get a better cut… (pun intended :D )
35128 posts in 4483 days
#8 posted 01-12-2008 06:26 AM
Cherry burns if you cut it too slow. Cut faster and it keeps the bit cooler. The hear is transferred to the sawdust.
View USCJeff's profile
USCJeff
1063 posts in 4150 days
#9 posted 01-12-2008 07:02 AM
Melamine is brutal. Tough on even the best cutters. If that is the only stock that “smokes”, it is probably a heavy pass in a tough material.
-- Jeff, South Carolina
dennis mitchell
3994 posts in 4397 days
#10 posted 01-12-2008 07:08 AM
Too deep a cut. Sounds like your bit might be dull.
View Blake's profile
Blake
3443 posts in 3956 days
#11 posted 01-12-2008 08:40 AM
You probably just need a new or sharpened router bit. Dull and dirty bits, knives, and blades are hard on your motors and can ruin your tools as well as your work. Cheap router bits are not worth using for very long. I have been trying to replace mine bit by bit as I can afford it, starting with the most used.
-- Happy woodworking!
View LONGHAIR's profile
LONGHAIR
94 posts in 3897 days
#12 posted 01-12-2008 03:13 PM
Clearing out the chips is a huge factor. From your discription, it sounds like you are routing dados, for shelves in cabinet sides. If so, you have several factors that cause heat build-up. The depth of cut in a “trapped” cut is part of it. Chips packing up behind the cut get worse as the length of the cut increases. The bit is a factor too. Straight fluted and spiral fluted bit will act very differently. Sharpness of the bit will obviously play into this too. Also, I am assuming carbide, either way…. The actual speed of cut is somewhat determined by these factors.
Reducing any of these factors will definately help.
CoolDavion
#13 posted 01-12-2008 05:17 PM
I was routing a dado for T-track in a Router Table.
I ended up making several shalow passes to finish up.
The bit was new (but cheap).
