Panel Saws
Forum topic by Bill posted 990 days ago 1227 views 0 times favorited 8 replies Add to Favorites Watch
View Bill's profile
Bill
2561 posts in 1055 days
990 days ago
Does anyone have experience with panel saws? I have seen some plans, and want to build my own to help with large plywood sheets. I have seen upright ones, as well as table types. The upright ones seem better, since they use less space. Any thoughts are appreciated.
View Dusty's profile
Dusty
785 posts in 1050 days
990 days ago
Bill,
I owned a Milwaukee model 6480-20 panel saw. I found it handy when I was alone and had to cut 4×8 sheets of thing. However, that said They take up a lot of space. They are hard to get plumb and square to start with and keep that way. I built a wheel and roller kid which made it a lot easier to handle. I would recommend the extension kit and the midway fence kit if you do buy one.
Over all it performed well, and if i did a lot of cabinet and space wasn’t a issue and I used it almost daily on 4/x 8 sheet goods -and was alone most of the time then I can see the need.
When I moved to my new shop I sold it. I replaced it with my new 3 hp Delta Unisaw with the large top. I can do everything with my table saw and more than I just did with the panel saw.
I don’t miss the panel saw and wish I would of bought the Delta Unisaw or large cabinet saw to start with.
-- Dusty
25793 posts in 1294 days
990 days ago
I can cut full sheets on my Exactor sliding table on my table saw. But I tend to cut up with a skill saw on sawhorses. Because of trying to manhandle 4 X 8 sheets by myself.
Then I trim to size on the TS
View oscorner's profile
oscorner
4572 posts in 1204 days
989 days ago
Bill, if you look at my workshop photo’s, I have a panel saw that I built. It will handle material up to 1” in thickness. It uses a regular circular saw. The magazine plan used a 18 volt circular saw, but I don’t have any issues with the cord. I need to make and add some adjustable guides for better control over the saw. When I made the guide I didn’t have a dado blade, so it has a little more slack than it should have. My cuts have been square,even with the slack. I think it was WorkBench that has the plans. I’ll try and get the exact issue for you.
-- Jesus is Lord!
View Obi's profile
Obi
2191 posts in 1131 days
989 days ago
I have a magazine with the plans to build a panel saw. Til then I use a skil saw and clamp a strait edge on it and with a 40 blade, looks like a factory cut.
We’re gonna have to get together, so I can show you some tricks of the trade. Why spend a buttload of money on a panel saw, when a real carpenter can cut it with a circular saw?
-- http://ye-olde-cabinet-shoppe.com/
View Obi's profile
Obi
989 days ago
How to build a Panel Saw Shop Notes Issue 88
oscorner
989 days ago
The panel saw, Obi is talking about is a very well made one. I opted not to build this one because of the complexity of it. The one I built is more of a manual saw, no springs or cables to help hold the saw and no pipe with rollers to allow for horizontal cutting, which is a neat ability. I just wanted something that I (alone) could put a full sheet of 3/4 ply on and cut into more managable pieces for the tablesaw. Granted I have to either use a circular saw with a straight edge or man handle a full sheet on my tablesaw if I need to rip a full sheet of plywood, but the idea was for most cabinets and other projects, seldom would I need longer pieces than 4’. There are several plans to pick from.
-- Jesus is Lord!
View Obi's profile
Obi
989 days ago
I actually shouldnt be so criticle, If I had room for a panel saw, I’d probably make one, because this man-handling full sheets of 3/4” plywood up on the table saw or onto saw horses is a pain …
View Bill's profile
Bill
989 days ago
I am looking to see if I have issue 88. It may have been before I subscribed to Shopnotes though.
Like all tools, they do have their place. I was thinking it would be easier to run panels through a panel saw rather than the sawhorse and straight edge method. I have also used a tablesaw, but that is tough work.
You do have a point. I have used the straight edge method so far with good results. However, it does take some time and effort ensure the straight edge is even at both ends (since I usually do not need angled cuts).
It is just one more thing on the tool wish list. I am trying to prioritize which items are necessary and which are nice to have. After my taxes are done, the necessary items will begin to be purchased.
