Where can I find this? (Part for venting outside)
Forum topic by Shane posted 11-30-2016 03:47 AM 735 views 0 times favorited 14 replies Add to Favorites Watch
View Shane's profile
Shane
294 posts in 1866 days
11-30-2016 03:47 AM
I have a Jet DC-1900 dust collector and I’m thinking about venting it outside but I would need a flange to replace the metal Y that goes to the bags with a pipe to go outside. Basically a rectangle flange that transitions to a four inch round pipe. Any idea where I can buy something like that?
14 replies so far
bandit571
20473 posts in 2738 days
#1 posted 11-30-2016 04:09 AM
MacDonald Supply up in Bellefontaine? If they don’t have it, they MIGHT make one for you.
View MrUnix's profile
MrUnix
6829 posts in 2254 days
#2 posted 11-30-2016 04:37 AM
Get the measurements of the rectangular opening and then hit a local HVAC supply house… look for a plenum register box that matches the size of the opening (or close enough to work if nothing else). They are quite common, at least around here, where you run a trunk line down the middle of the attic and string off individual outlets from it using round flex hose to the registers… and 4” is a pretty common size. You might also find some square to round transitions that could work.
View wichman3's profile
wichman3
67 posts in 676 days
#3 posted 11-30-2016 04:53 AM
Why not build a box out of 3/4 plywood, just big enough to clear the rectangle and bolt to the DC. Make it about 4 inches deep and drill a 4 inch hole in the opposite side.
I’ve used this technique on the suction side of my DC.
Shane
#4 posted 11-30-2016 01:13 PM
Thanks guys. I’m going to mill around Lowe’s today when I go to pick up something else and see if they have anything like that in the HVAC stuff. If not I will check out MacDonald Supply
View Bill7255's profile
Bill7255
427 posts in 2340 days
#5 posted 11-30-2016 01:33 PM
I just built a plywood box. I also did 7” for the exhaust as that was the best match area wise to the jet. This works just fine.
-- Bill R
Shane
#6 posted 11-30-2016 04:20 PM
That looks cool Bill. Do you get any issues with dust or chips getting stuck in the corners of the box before they get pushed into the round opening?
Shane
#7 posted 11-30-2016 04:35 PM
i don’t have a chip separator yet so I’m concerned about that.
Bill7255
#8 posted 11-30-2016 04:42 PM
Shane. I set this up with the eBay cyclone, so there is no issue for me with chips. My biggest problem was standing it up, since I don’t have any help. I ended up moving my HF hoist temporally to stand it up. As said I did 7” exhaust as this matched the cyclone exhaust and area wise the Jet exhaust. What you could do is use a piece of plexiglass to monitor if necessary. I do not get any visible debris outside at all.
Edit: I would do some type of separator. My cyclone was about $250 shipped.
-- Bill R
Shane
#9 posted 11-30-2016 04:50 PM
I would like to at some point. I will probably not vent to outside until I have one.
Shane
#10 posted 11-30-2016 04:51 PM
Do you have any idea what the micron rating on the bags that come with the Jet are? I have the white DC-1900 and I can’t find any documentation on that.
Shane
#11 posted 12-01-2016 01:36 AM
Bill I can’t find the cyclone like yours for sale. Any tips on finding it?
Bill7255
#12 posted 12-01-2016 03:05 AM
Cyclone
I could only find the small one on eBay. I think he is selling them through here now.
http://cycloneseparator.com
The large one appears to be the same as I have.
Bags
My 1900 was the older blue vintage. It had 30 micron bags, don’t know about the white 1900 bags.
-- Bill R
Shane
#13 posted 12-01-2016 03:55 PM
I did confirm that it was the 30 micron bag as well. I decided to order some 1 micron bags to replace them until I can get it set up to vent outside. The nice thing is that I have a storage closet in my shop that the DC fits nicely into so I just ran the power to that, and now I can run it in there with the door shut. Once I get it venting outside it will be dumping directly onto our compost pile which will be nice, and we live in the country so it won’t annoy anyone.
Shane
#14 posted 12-06-2016 03:36 PM
Got the table saw and planer hooked up to the dust collector last night. I just need to get the jointer done now. I found a few things I want to tweak but otherwise I’m pretty happy with it.
I’m having a little trouble getting the new bags on the collector to make a perfect seal and I need to install the blast gates (which are supposed to arrive today). I also ordered a couple of 45 degree elbows to ease the transitions from the ceiling to the floor level when it drops down.
