Diagnosis my tablesaw motor pop
Forum topic by Jeff_in_LSMO posted 11-28-2016 09:15 PM 1066 views 0 times favorited 23 replies Add to Favorites Watch
View Jeff_in_LSMO's profile
Jeff_in_LSMO
352 posts in 2486 days
11-28-2016 09:15 PM
I’ve been putting more time in on my tablesaw lately, and today when cutting through a piece of thick maple the saw made a dull pop sound, stuttered a bit, and then I could smell electrical fault. I quickly turned it off, unplugged, and got the fire extinguisher at the ready.
After opening the cabinet, everything looks normal, except the, excuse my french, peckerhead was hot.
Given that I probably know the outcome, what happened? Is that the end of the motor?
UPDATE: got to taking apart the motor; here is what’s left of the capacitor
23 replies so far
View HerbC's profile
HerbC
1790 posts in 3005 days
#1 posted 11-28-2016 09:30 PM
Toast?
Hopefully not. Might be just a lead shorting out in the p-head. Disconnect the power, say a prayer and open up the connection box and check it out.
Good Luck!
Be Careful!
Herb
-- Herb, Florida - Here's why I close most messages with "Be Careful!" http://lumberjocks.com/HerbC/blog/17090
View MrUnix's profile
MrUnix
6935 posts in 2345 days
#2 posted 11-28-2016 09:35 PM
Would be kind of helpful if we knew what kind of saw/motor you have. Just pulling stuff out of thin air, maybe the centrifugal switch spring broke? If it was still running when you cut power, it ain’t toast yet and probably an easy fix.
View splintergroup's profile
splintergroup
2305 posts in 1368 days
#3 posted 11-28-2016 09:35 PM
Could be an internal breaker popped or the start/run capacitor let out the magic smoke. Motors are generally well protected these days.
View mahdee's profile
mahdee
3992 posts in 1914 days
#4 posted 11-28-2016 11:31 PM
I am thinking the capacitor. Mine did the same thing but it was the bearing that had seized up.
-- earthartandfoods.com
View CLowery15's profile
CLowery15
24 posts in 1029 days
#5 posted 11-29-2016 01:22 AM
I just replaced the run capacitor on my Craftsman Contractor Table Saw…the old one was a Ming Fun capacitor from Taiwan, which I wasn’t going to try and find…so I wired in a 30 microfarad, 370vac run capacitor…the saw runs much much quieter.
-- - Craig
Jeff_in_LSMO
#6 posted 11-29-2016 02:06 PM
excellent to hear clowery15. Not being good with electronics, what do i do? What does a capacitor look like? How do i know if it is bad? How do I replace it? etc?
View WhyMe's profile
WhyMe
1053 posts in 1707 days
#7 posted 11-29-2016 02:24 PM
- JeffinLSMO
If you search the web for “test and replace motor capacitor” you’ll find plenty of information. Lots of YouTube instructions.
View Bonvivant1's profile
Bonvivant1
31 posts in 1120 days
#8 posted 11-29-2016 06:18 PM
If you are going to tackle a change of capacitor make sure you read about discharging capacitors. A capacitor can contain enough of a charge to potentially kill you. Some people simply place a screw driver across the terminals to discharge a capacitor. I think this is dangerous. I use a contraption I rigged with a light bulb. You can also use resistors, depending on the size of the capacitor. Be safe!
-- You took your first pinch like a man and you learned the two greatest things in life...Never rat on your friends and always keep your mouth shut.--Jimmy Conway
MrUnix
#9 posted 11-29-2016 06:35 PM
Given that there was an audible ‘pop’, you should be able to instantly tell if it was the capacitor, as it would be split open or otherwise show signs of an unusual failure. Capacitors rarely explode… usually it’s the dielectric fluid that breaks down over time, sometimes resulting in bulging or leakage, but not always. If there is no physical damage that can be detected, it can easily be tested with a multimeter on its resistance setting.
But since there was an audible clue – that points more to a mechanical failure. Most likely will require opening up the motor to see what happened. Without knowing what type of motor we are talking about, it’s still all just a guess though.
PS: The capacitors on a small motor won’t store enough juice to do much damage, and shorting the terminals out with a screwdriver works just fine. If you were playing with the capacitors in something like an old TV or microwave oven however, that is a different story!
Bonvivant1
#10 posted 11-29-2016 09:35 PM
I have no idea whether the capacitor would hold enough charge to hurt the OP. However, either way I would be careful.
As to discharging a capacitor with a screwdriver, I know it is done a lot, however, it is not the proper way to do it.
CLowery15
#11 posted 11-30-2016 02:30 AM
Hi Jeff…well, first, the capacitor stunk, then when I took off the metal cover, it was bulging out in several areas. The capacitor I reploneaced it with was a 2” diameter capacitor…granted it didn’t fit in the metal case. so, I zip tied it to the outside of the motor and wired it up.
Put several pieces through the saw this evening and it runs great. I don’t know what saw you have, but the one that blew in mine was rated at 30 microfarad / 350vac. So, you want to go up in voltage, not down & keep the microfarad rating. That’s why I went with the 30 microfarad / 370 vac capacitor. $13.25 as compared to $150.00 was an easy sell.
replacing is simple…even though a new one will have several areas for connections, I had 2 wires that came from the motor…I simply crimped a male connector on each wire, and slid them on each side…just place the crimped wire on each side and you should be good to go.
Hope this helps & best of luck!
-- - Craig
Jeff_in_LSMO
#12 posted 12-01-2016 06:37 PM
update, the capacitor was done. see pics.
Jeff_in_LSMO
#13 posted 12-01-2016 06:57 PM
so how do i know if this is the starting or run capacitor, and how do i select a replacement? i’m pretty sure it is a start capacitor.
MrUnix
#14 posted 12-01-2016 07:09 PM
Everything you need to know is written on that label stuck to the side of the capacitor. Can’t really read it good, but looks like 35uF?? Can’t make out the voltage. Maybe post a better, non-blurry picture.
Jeff_in_LSMO
#15 posted 12-01-2016 07:16 PM
Huizhong CBB60
35uF +/- 5% SH
250 VAC 50/60hz
25/70/21 C P0
