Duro Metal Products 12" Band Saw
Forum topic by hig789 posted 11-28-2016 04:20 PM 1928 views 0 times favorited 15 replies Add to Favorites Watch
View hig789's profile
hig789
39 posts in 1014 days
11-28-2016 04:20 PM
I have the opportunity to buy one of these for $50. The women said her husband wasn’t home right now so she couldn’t tell me if it is in good working order or not. By the one picture it looks like it’s in pretty good shape but that doesn’t mean anything. It’s about a hour and 45 minutes away from me so I’d like to get some opinions on it before I went any further talking to them.
I saw a bunch of post on the 15” and 16” floor models but couldn’t really find anything on this one.
I have a 3 wheel Craftsman 10” saw right now so anything would be a upgrade on that haha. Let me know what you think about it. Are parts hard to find?
Here’s the only picture they had.
Thanks everyone.
15 replies so far
View Loren's profile
10477 posts in 3820 days
#1 posted 11-28-2016 05:18 PM
If it were closer, I’d say go for it but considering
the distance…
Those saws were not made after the 1960s and
parts are not available. This is not a big deterrent,
imo, since band saws are simple machines and
it does not appear to be broken. What is of concern
is whether you can get blades for it easily.
View MrRon's profile
MrRon
5136 posts in 3416 days
#2 posted 11-28-2016 05:43 PM
I’d say; go for it. Getting blades is not a problem as all industrial supply houses will make up a blade of any length. I’m pretty sure it will need some fixing, but it was a pretty solid machine in it’s day. Certainly in a comparison with a Chinese machine, the Dura wins hands down.
hig789
#3 posted 11-28-2016 06:03 PM
They said it doesn’t run because it doesn’t have a motor. That’s not a big problem because I have a few I could use. Just worried about the bearings and such.
hig789
#4 posted 11-28-2016 06:10 PM
Any specific questions that I can ask them? They don’t seem too knowledgeable about it.
View MrUnix's profile
MrUnix
7004 posts in 2372 days
#5 posted 11-28-2016 06:12 PM
Figure on replacing the bearings anyway, before you put it into use – even if you ‘think’ they are good. For a machine that age, I doubt they have ever been replaced and are on their last gasp. Cheap insurance to prevent damage in the future.
runswithscissors
2869 posts in 2198 days
#6 posted 11-29-2016 05:37 AM
. . . and don’t worry about finding bearings. Just pull the old ones, and take them to a bearing shop, or let your supplier know the bearing numbers, diameter, etc.. All manufacturers use standard, off-the-shelf bearings rather than making their own propietorial ones.
View AHuxley's profile
AHuxley
818 posts in 3494 days
#7 posted 11-29-2016 08:48 AM
- runswithscissors
In this case that is true BUT it is not the case with all older machines, Walker Turner is an example of using bearings on some of their machines that are impossible to source now.
View Nubsnstubs's profile
Nubsnstubs
1414 posts in 1903 days
#8 posted 11-29-2016 02:35 PM
I have the 14” Duro. Got it in ‘78 when it was already 20 years old. Has worked flawlessly since getting it. It has never had anything replaced on it since….......... Jerry (in Tucson)
View Woodknack's profile
Woodknack
12398 posts in 2553 days
#9 posted 11-29-2016 04:56 PM
- AHuxley
I’ve heard that but have always been skeptical. They were relatively inexpensive machines, I can’t imagine they could afford actual custom bearings and still be competitive. There is such a thing as mixed inch/metric bearing and they throw people because no one expects mixed units in a bearing. My ‘58 Craftsman lathe used them. I wonder if that isn’t what they used and people thought it was something custom because it won’t match any standard inch or metric bearing.
MrRon
#10 posted 11-29-2016 08:07 PM
They were relatively inexpensive machines, I can t imagine they could afford actual custom bearings and still be competitive.
- Rick M
“Relatively inexpensive machines” 50 plus years ago were a lot different from inexpensive machines of today. Back then, they were made to last. Today, they are made to last only until the warranty expires.
hig789
#11 posted 11-29-2016 08:42 PM
Well I told them I’d take it. Just need to go get it this weekend. I have been looking for a older band saw for months so I can’t wait to go get it. I’ll post some pictures after I get it.
Woodknack
#12 posted 11-29-2016 10:00 PM
- MrRon
As a past and present owner of a few old machines, cheaply sold is cheaply made regardless of decade, but I was speaking to the bearings and custom bearings would have boosted the cost with no improvement to quality and no marketing advantage. Maybe someone thought there would be a market for replacement bearings but if you want to make a buck, you charge for consumables, not parts that may take decades to wear out. I’ve had machines from the 50’s that were poorly made but still running on the original bearings.
hig789
#13 posted 12-06-2016 12:49 AM
Well I went and picked the saw up yesterday. It turned out to be a rebadged Duro for Wards Powr Kraft line. It still has some of the original finish on the base of it. Gotta get some new tires for it and possibly change out the bearings but I very happy with it over all. Gonna try and get a motor on it this weekend and try to find a blade. The guy gave me a broken blade that he said measures 77”. Need to check it myself and try to order one from somewhere.
runswithscissors
#14 posted 12-06-2016 02:11 AM
Any saw shop and weld you up a blade of whatever length you want. Not terribly expensive, depending on the blade, of course. If you don’t have such a shop near you, this can be done online.
hig789
#15 posted 12-06-2016 01:09 PM
Any saw shop and weld you up a blade of whatever length you want. Not terribly expensive, depending on the blade, of course. If you don t have such a shop near you, this can be done online.
- runswithscissors
Yeah. I think the closest one I have to me is about 45min to a hour away. I’ll have to do some more checking.
Got started cleaning the saw up a little last night and got to look at it a little closer. Under the dirt and mud dobber nests it’s pretty much like new. It has seem very little use from what I can tell. The original wrinkle finish is there, it just needs a little cleaning.
First thing it needs is new tires and a blade though. The original rubber tires on it are pretty thick. I think I’m gonna order some urethane ones and then measure for the blade length so I don’t get one that’s too long.
Edit: not sure why all my pictures are uploading sideways. Sorry. I’ll try and fix that.
