Jet Extension Wings/Rip fence
Forum topic by Greg67 posted 11-28-2016 03:28 PM 513 views 0 times favorited 4 replies Add to Favorites Watch
View Greg67's profile
Greg67
6 posts in 699 days
11-28-2016 03:28 PM
Topic tags/keywords: jet rip fence extension wings table saw for sale
Hey folks,
I have a (new to me) JET 10” Arbor Saw
Model JTAS-10-1
My woodworking pal gave it to me last week.
The only thing is, it has no fence or wings.
I can’t find affordable ones. (Of either)
Any help here would be greatly appreciated.
-- Stand for something or you'll fall for anything
View HerbC's profile
HerbC
1790 posts in 3008 days
#1 posted 11-28-2016 04:01 PM
Other than trolling EBay and Craigs list looking for old saws/parts here’s what I’d do:
Fence: Delta T3 from Home Depot. About $200 bucks and should fit the saw with minimum adaptation (may need to drill and/or tap some holes for rail mounting but cast iron should work easily….
Wings (extensions): Make your own from hardwood and other material. Use hardwood for framework and some sheet material (plywood or MDF/MDO) for the surface area. You might want to use laminate (formica) to cover the surface, makes it slick and durable. I used Corian scrap on mine, works fine.
Good Luck and remember…
Be Careful!
Herb
-- Herb, Florida - Here's why I close most messages with "Be Careful!" http://lumberjocks.com/HerbC/blog/17090
Greg67
6 posts in 699 days
#2 posted 11-28-2016 04:09 PM
Thanks Herb. Heard a lot about that fence. Looking into it this weekend.
HerbC
#3 posted 11-28-2016 04:17 PM
- Greg67
You won’t find it in the stores, it’s Internet order only. The link I list above should take you right to it.
Good Luck!
Herb
View knotscott's profile
knotscott
8129 posts in 3524 days
#4 posted 11-28-2016 05:30 PM
The stock fence for that saw would be the Jet Xacta II, which is a good Biese Commercial clone, and likely a tad expensive. AFAIK, it’s the same fence as the HTC, which might be a bit cheaper. The Shop Fox Classic would be a good alternative, but is still north of $300.
The Delta T3 is about the best fence in the $200 range I can think of….it’s a somewhat lighter duty of the original XactaII fence. You might need to drill or redrill a couple of holes in the cast iron.
Vega makes a couple of nice fences that are a good bang for the buck too.
