should I get a dado blade
Forum topic by Rdub posted 11-28-2016 03:27 PM 1145 views 0 times favorited 20 replies Add to Favorites Watch
View Rdub's profile
Rdub
2 posts in 784 days
11-28-2016 03:27 PM
Topic tags/keywords: dado router blade tablesaw
Hello all, I am thinking about getting a dado blade, looking at Oshlun SDS-0630 6-Inch 30 Tooth Stack Dado Set and the Freud SD208 8-Inch Professional Dado, both are the same price. Just wondering which is best, I have a contractor saw 1.75 hp motor. I would be using it for all types of wood. Currently I am using my router. I am also wondering if it is even woth the expense to get a dado blade or should I just keep usingmy router. I am fairly new at woodworking and I am looking at building my own kitchen cupboars in my small basement shop. Any advice will be greatly appreciated. Thanks
20 replies so far
View knotscott's profile
knotscott
8179 posts in 3615 days
#1 posted 11-28-2016 03:49 PM
Everyone’s preferences are different, but I find that I like the added mass and power of using a stacked dado on the table saw vs a router…..though both have their pluses.
Those are both decent options at that price point, but I’d opt for the Delta/DeWalt 7670 over either…cleaner cuts, great carrying case. It’s worth a few extra bucks IMO.
View Cooler's profile
Cooler
299 posts in 1082 days
#2 posted 11-28-2016 04:55 PM
I like a stacked dado. The fence on the saw is very handy for that work, and with shims I get perfectly fitting dados.
When making shelves I will cut the dados in double-width material and saw it apart for lefts and rights. It guarantees alignment left to right and gives a larger contact area with the fence.
A dado head with a negative hook angle will make cleaner cuts in plywood and melamine covered particle board, and will work in a radial arm saw. I have both and I usually use the negative hook angle set.
Order shims for a very accurate setup. They did not come with my Freud dados.
The smaller stack (6”) will cause less strain on your motor and it is rare that you need more than a small amount of depth for dados.
Just a side-bar the old time book that I learned table saw usage from distinguished dados from grooves. Only those cut cross grain on solid lumber were dados; the rest were grooves. I still use that distinction but I get some strange looks for using “grooves” on occasion.
-- This post is a hand-crafted natural product. Slight variations in spelling and grammar should not be viewed as flaws or defects, but rather as an integral characteristic of the creative process.
View HokieKen's profile (online now)
HokieKen
7584 posts in 1378 days
#3 posted 11-28-2016 05:28 PM
I have the Freud SD208 set and I like it. It does come with shims and a carrying case and a handy guide on what combination of chippers and shims to use for common widths. At the price point, I would recommend it. I have no experience with any other dado stack to compare it to though.
That being said, unless I have a lot of identical cuts, or heavy cuts, to make I still find myself using the router table more often than the dado set. Router setup is just faster for me.
-- Kenny, SW VA, Go Hokies!!!
Cooler
#4 posted 11-28-2016 05:36 PM
- HokieKen
Dado setup can be time consuming. Mostly I am setting up for 3/4” ply. And I can get very close on my initial setup but big box plywood is not always the same thickness so shimming is inevitable and that takes time, sometimes 3 or 4 tries before I get it where I want it.
And then I have to make sure that all the stock is the same thickness. I bought some melamine covered particle board from Lowes. I picked two sheets from the same lot and was rudely surprised when one set of shelves was too tight. I reduced the thickness at the ends by standing the shelves up vertically and setting my table saw blade at 3/8” depth and taking a skim cut—maybe 0.005” or 0.008”, just barely the thickness of the melamine. It was much easier than going back and re-stacking the dado head for the thicker boards.
View Carloz's profile
Carloz
1147 posts in 831 days
#5 posted 11-29-2016 02:39 PM
Hokiekem,
Yes the blade setup for random plywood width is time consuming, however with a router you do not have a choice at all. Router bits come in preset width with very limited selection. You have to do double pass, but you can do it on the table saw and easier.
Where router does beat dado stack is the cleaness of the bottom of the cut. Mine are very rough.
View WhyMe's profile
WhyMe
1080 posts in 1800 days
#6 posted 11-29-2016 02:54 PM
I have a 6” and a 8” dado and I like using the 6” better. It just seems to run better on the saw, not as much load.
View MT_Stringer's profile
MT_Stringer
3183 posts in 3470 days
#7 posted 11-29-2016 03:13 PM
i use a router and an exact width dado jig. I am assembling the last three of 16 kitchen cabinets. All dadoes fit nicely. No fuss, no muss.
Cooler
#8 posted 11-29-2016 05:14 PM
Hokiekem,
- Carloz
Mine are rough if I am cutting plywood and I hit the glue surface; not bad otherwise. But what difference does it make? It is completely hidden anyway?
View pintodeluxe's profile
pintodeluxe
5817 posts in 3052 days
#9 posted 11-29-2016 06:03 PM
I use dado sets often, and I think the fundamental action of cutting grooves with a tablesaw is better than with a router. A spinning router bit can make a straight cut , but it wants to veer off course given a chance. The dado head spins in-line with the groove, and makes really consistent cuts.
For plywood joinery, the inexpensive sets are fine. I used a Diablo set for years, and it cut perfectly in finish plywood. I’ve had it sharpened and it keeps on going. For hardwood joinery like cutting tenons, I prefer a set with more teeth. If you get a set with 24 teeth outer blades, and 4 teeth on the chippers you will notice less tearout with hardwood joinery. I use an Infinity set for that type of work.
View 000's profile
000
2859 posts in 1138 days
#10 posted 11-29-2016 06:14 PM
If you want to rout your dado’s you can buy different size cutters for different thicknesses of material.
I do a lot of dado’s so I have quite a collection of different sizes, so it’s worth it for me to use these?.
If your not doing many, I would get a nice stacked dado blade instead.
View Gaffneylumber's profile
Gaffneylumber
103 posts in 1068 days
#11 posted 11-29-2016 06:19 PM
I have the Oshlun 6” and like them a lot. I’m sure the freud’s are great too. Setup time in a router can be annoying so I like the dados personally.
-- Grayson - South Carolina
MT_Stringer
#12 posted 11-29-2016 08:01 PM
Shop made one time use exact width dado jig for upper cabinet sides (one dado on each end). All I have to do is unscrew one piece and readjust it for a different thickness next time. Works like a charm. I clamped it to the work table, inserted a cabinet piece, cut the dado, flip to the other end, repeat. Done deal!. Clean well fitting dado.
View Rdub's profile
Rdub
2 posts in 784 days
#13 posted 11-29-2016 08:44 PM
Thanks for all the responses so quickly, I am still debating so I think I will stick with my router for now and keep saving so I can buy a better set maybe the Delta/DeWalt 7670. In the meantime I will make the jig as in MT_Stringer’s post, it’s a real good way to get them done, thanks for the post MT.
MT_Stringer
#14 posted 11-29-2016 09:13 PM
Thanks for all the responses so quickly, I am still debating so I think I will stick with my router for now and keep saving so I can buy a better set maybe the Delta/DeWalt 7670. In the meantime I will make the jig as in MT_Stringer s post, it s a real good way to get them done, thanks for the post MT.
- Rdub
What you don’t see is there is a stop block under the right side of the jig which will position the end of the cabinet side perfectly every time.
Good luck.
Mike
With the stop in place, your dadoes will be consistent.
Note that I use a 1/2 inch pattern bit and make two passes to create a 1/4 inch deep dado.
View dalepage's profile
dalepage
380 posts in 1080 days
#15 posted 11-29-2016 09:25 PM
Don’t buy the 6-inch! I use a sled for my dadoes and when you add the thickness of the sled, you may not be able to get a deep enough dado in your stock.
I don’t use a dado blade often, but if it’ll go on the sled, it’s sure easier than setting up a cut with the router and a straight edge.
-- Dale
