Caliper for blade alignment? Suggestions needed
Forum topic by LucasWoods posted 11-27-2016 10:52 PM 535 views 0 times favorited 10 replies Add to Favorites Watch
View LucasWoods's profile
LucasWoods
435 posts in 1389 days
11-27-2016 10:52 PM
What do you all use to square your TS blades and other blades in the shop? I have done some research and pretty much settled on a digital caliper… if you got one or use something else let me know how you like it
-- Colorado Springs, CO - USAF
10 replies so far
View Redoak49's profile
Redoak49
3340 posts in 2044 days
#1 posted 11-27-2016 11:08 PM
I use a high precision steel square to align to 90 degrees as a set up. For lots of other things use a digital tilt box.
View Woodknack's profile
Woodknack
12082 posts in 2436 days
#2 posted 11-27-2016 11:26 PM
I used to use a machinist square, now I use a Wixey. I like the Wixey better and my joints are tighter.
View HokieKen's profile
HokieKen
5670 posts in 1194 days
#3 posted 11-28-2016 01:33 AM
Same here, Wixey box. Machinists square on occasion.
I’m not sure we understand what you mean by square though. We’re thinking square to table on the tilt. Not sure how you would swing that with a caliper though. A little more explanation may get you better answers.
-- Kenny, SW VA, Go Hokies!!!
MrUnix
6830 posts in 2255 days
#4 posted 11-28-2016 01:42 AM
I was asking myself the same thing. I just use a combination square that I’m sure is square. For the TS, you only have to do it once. For the others (band saw, scroll saw…), the smaller size is required to get up to the blade without hitting the guides/clamps.
View brtech's profile
brtech
1034 posts in 2978 days
#5 posted 11-28-2016 02:35 AM
You can use a caliper with a jig to make sure the blade is parallel to the miter slot and the fence is parallel to the miter slot. Usually, however, we use a dial indicator with a jig for that. I have a jig to use with my caliper for that task. It holds the caliper at a nominal 90 degrees to the miter slot, and you use the tail of the caliper touching the blade near a tooth, zero the caliper, swing the blade over 180 degrees, slide up the jig and measure the distance to the same spot on the blade. Zero difference means the miter slot is parallel to the blade. If it’s not, you loosen your trunnions and move the arbor relative to the top (and thus the miter slots).
I use an iGauging equivalent of the Wixley, or an engineer’s square.
Woodknack
#6 posted 11-28-2016 03:33 AM
You can use a dial indicator to set a blade square to the table but it’s a two step process and you need a known good square to set up the dial indicator.
http://lumberjocks.com/projects/84217
Click for details
HokieKen
#7 posted 11-28-2016 12:30 PM
You can use a dial indicator to set a blade square to the table but it s a two step process and you need a known good square to set up the dial indicator.
Click for details
- Rick M
You could use that jig with a caliper too. Wouldn’t be quite as accurate and making a mount is a bit more involved but it’s definitely do-able.
FWIW, I use essentially the same jig as Rick shows in his project above except mine’s just for alignment, I’ve never used it to set the blade angle. You could also use it to set precise blade angles with a little trig’.
Redoak49
#8 posted 11-28-2016 12:52 PM
Very interesting idea with dial indicator and very accurate check.
The dial indicator is an excellent and low cost tool for all kinds of machine set up. Building jigs to use it with greatly increases flexibility.
View ChefHDAN's profile
ChefHDAN
1070 posts in 2905 days
#9 posted 11-28-2016 01:24 PM
For doing the alignments of the blades and fence I really like the Woodpecker Saw Gauge , I bought it when I saw it for $49 at Peach tree i think, i see it right now most places for $70. I have dial indicators and have used the combo square but have found that this tool is super quick and simple to come out of the box and either double check alignment of correct alignment, I’d say it easily cuts the time in half from using the other tools, but then I’m not a machinist.
View MrRon's profile
MrRon
4869 posts in 3299 days
#10 posted 11-28-2016 06:12 PM
Use a combination square to set the blade parallel with the miter slot. Mark a tooth on the blade and with that tooth close to the front, adjust the square with the head riding along the slot until it just scrapes the tooth. Then rotate the blade so the same tooth is at the rear of the table and repeat. Feeler gauges are useful.
To set the fence parallel to the blade, rip a piece of scrap wood or plywood about 2 or 3” wide by at least 12” long and measure both ends of the ripped wood with a caliper, either digital or dial is fine.
To set the blade 90° to the table top, use a small machinist’s square, placed against the “plate” portion of the blade (not against a tooth). The combination square may also work.
To set the miter gauge 90° to the blade, place the square, either one with the head against the miter gauge haed with the blade against the flat side of the blade. Be careful as to not touch any teeth.
To set angles, I use a Wixey tilt box.
As far as the tools you will need, it can all be done with a combination square, a caliper and an angle setting device like a Wixey.
