How do I make this wood joint for a butchers block
« back to Joinery forum
Forum topic by Rochesterwood posted 11-27-2016 02:05 PM 2279 views 1 time favorited 17 replies Add to Favorites Watch
View Rochesterwood's profile
Rochesterwood
5 posts in 630 days
11-27-2016 02:05 PM
Topic tags/keywords: joining butcher block wood
I have recently restored an old butchers block. I want to recreate it myself but I am unsure how to make the joints that are connecting the wood. How do you make these is there a tool or a machine I need to make them?
17 replies so far
View johnstoneb's profile
johnstoneb
2994 posts in 2256 days
#1 posted 11-27-2016 02:25 PM
Those are sliding dovetails. Router, dovetail bit and straight edge and lots of practice. There are also dovetail jigs available that will make short sliding dovetails and there are hand planes available to make dovetails also. Dovetails require a lot of practice to get right.
That is a beautiful old butcher block. It has definitely seen a lot of use. Those dovetails are probably one reason it has lasted as long as it has. Most butcher blocks I have seen just face glue the wood with no joints They will last a long time but not like the one you have.
-- Bruce, Boise, ID
117166 posts in 3660 days
#2 posted 11-27-2016 05:05 PM
Rochesterwood
5 posts in 630 days
#3 posted 11-28-2016 01:23 AM
Thank you a1jim and Bruce I really appreciate the input. I have been looking if there was a specific way to do it on the edge of boards but maybe I just have to experiment.
#4 posted 11-28-2016 01:48 AM
BTW Welcome to Ljs Rochester
I would guess that there is more than just the ends that are dovetailed,It looks like the dovetails go all the way from top to bottom. Take a look at the bottom and if there are dovetails on the bottom too then they go all the way through.
Rochesterwood
5 posts in 630 days
#5 posted 11-28-2016 01:53 AM
Thank you I am new to the forum scene so this is all new.
And yes you are correct it does go all the way from top to bottom on each board.
View DirtyMike's profile
DirtyMike
637 posts in 985 days
#6 posted 11-28-2016 01:55 AM
I am curious, was a shaper was used to cut those dovetails?
#7 posted 11-28-2016 02:01 AM
I would guess if these were factory made a shaper with a power feeder would be a good choice to make that much sliding dovetail area,but it could be done on a router table and even a table saw with the right set up.
Rochesterwood
5 posts in 630 days
#8 posted 11-28-2016 02:07 AM
Thank you I am in the middle of restoring an old craftsman table saw once that’s finished maybe I’ll play around with it! Thank you!
View IowaBeauty's profile
IowaBeauty
11 posts in 628 days
#9 posted 11-28-2016 02:11 AM
How could they not go all the way through?
#10 posted 11-28-2016 02:17 AM
Here’s some information on using a table saw to make sliding dovetails.
https://www.canadianwoodworking.com/tipstechniques/sliding-dovetails
#11 posted 11-28-2016 02:43 AM
Welcome to Ljs Iowabeauty
I can think of some ways but why wouldn’t you have them go through all the other ways would be a big hassle to make.
View jbay's profile
jbay
2488 posts in 982 days
#12 posted 11-28-2016 03:03 AM
- a1Jim
My brain must not be working properly, I’m having trouble picturing how a shaper could cut a dovetail. Is that possible?
I could picture doing the tenon, 1 side at a time.
#13 posted 11-28-2016 03:33 AM
Hi J
My father inlaw use to make them on his tilting head shaper with cutters he ground himself.
View JDCDDesign's profile
JDCDDesign
8 posts in 628 days
#14 posted 11-28-2016 06:12 AM
Alot of great information here! Iv also been wondering how to make these sliding dovetail joins.
-- James, Victoria, BC https://www.youtube.com/user/JamesDCD92
View jbay's profile
jbay
#15 posted 11-28-2016 05:07 PM
Hi J
- a1Jim
I still can’t picture it, but if you say so.
We are talking about the mortise, right?
May be possible to make one half of the mortise cut at a time, but the throat would end up being pretty wide.
