Standard House Wiring To 240?
Forum topic by jonnybrophy posted 11-27-2016 01:06 AM 700 views 0 times favorited 15 replies Add to Favorites Watch
View jonnybrophy's profile
jonnybrophy
160 posts in 519 days
11-27-2016 01:06 AM
Topic tags/keywords: tools noob 110 volts wiring
Hey guys, im just browsing craigslist and I found a decently good find
https://orlando.craigslist.org/for/5824982583.html
I really want it. Its a HUGE upgrade for me, but my question is
What do i have to do power wise? I am not much of an electrician, and I dont own my house(Im 18), so i dont think ill be able to do anything drastic.
Is 110 to 240 to much? or is it exspensive?
All help is appreciated
-- "If she dont find ya handsome, she better find ya handy"
15 replies so far
View BorkBob's profile
BorkBob
127 posts in 2600 days
#1 posted 11-27-2016 01:27 AM
Hi Jonny,
Standard residential electrical service is two “legs” each providing 120 volts. In order for 120 to work, it needs a second wire (neutral). Usually the service comes to the house via 3 cables. Two 120 volt “hots” and one neutral.
If you want 240 volts, you use the two 120 volt lines, no neutral needed. A third wire in 240 volt circuits is called an equipment ground and the only time it carries current is if something is wrong. It carries the “wrong” current to the ground (earth) instead of thru your heart and brain.
There are now 4-wire 240 volt circuits. A neutral wire is added to accommodate 120 volt devices, such as a light inside the dryer.
Talk to the home’s owner about your house’s electric service. You may be able to work out a deal.
-- Please Pray for Our Troops / Semper Fi / Bob Ross / www.theborkstore.com
jonnybrophy
#2 posted 11-27-2016 01:41 AM
Thanks Borkbob!
Would you say this is a simple process?
im still a little lost, but i get the idea.
View MrUnix's profile
MrUnix
6366 posts in 2107 days
#3 posted 11-27-2016 01:48 AM
Your house is already wired for 240v, at the breaker box at least. And you should have at least a few 240V circuits, such as for the A/C, heater, range and other large electric loads. Got a clothes dryer outlet anywhere near where you would want to have the saw?
PS: That saw is way over priced IMO.
View HokieKen's profile
HokieKen
4625 posts in 1046 days
#4 posted 11-27-2016 02:23 AM
I agree with Brad. $850 is pretty steep for that saw.
-- Kenny, SW VA, Go Hokies!!!
View sawdustdad's profile
sawdustdad
354 posts in 793 days
#5 posted 11-27-2016 02:31 AM
Best to get a qualified electrician to help you with this.
-- Murphy's Carpentry Corollary #3: Half of all boards cut to a specific length will be too short.
BorkBob
#6 posted 11-27-2016 09:12 PM
If you work with plumbing, you can get wet and/or stinky. If you work with electricity, you can get dead.
I admire your “can do” attitude, but you really do need professional guidance.
jonnybrophy
#7 posted 11-27-2016 09:15 PM
Thanks guys! just so happens, i work in my garage, a mere 10 or so feet from my washer and dryer. Is it as simple as just plugging into that oulet?
Thanks borkbob, but its all a beginner can do, am i right:)
P.S. I may not know what i am doing, but i know not to get myself killed:P dont worry, I wont touch anything until i have consulted a proffessional.
jonnybrophy
#8 posted 11-27-2016 09:16 PM
Also, what do you think i could get that saw for? 500 maybe? or should i just keep waiting for a better one to come along?
View AHuxley's profile
AHuxley
652 posts in 3229 days
#9 posted 11-27-2016 09:48 PM
Ad as deleted.
View dhazelton's profile
dhazelton
2689 posts in 2204 days
#10 posted 11-27-2016 10:22 PM
If you are renting don’t touch the electric in the house without checking with the landlord. It may need a permit in your locality and if you do it illegally you may find yourself looking for another rental.
jonnybrophy
#11 posted 11-27-2016 10:24 PM
Guys, i live with my parents, we own the house.
And unfortunatley i see that the ad is deleted.
Hopefully it will be reposted
View runswithscissors's profile (online now)
runswithscissors
2655 posts in 1933 days
#12 posted 11-28-2016 01:03 AM
Keep your eye out. More saws will come along, and at least one (all you need) will be at a better price.
Yes, by all means use your dryer outlet for 240v. All you need is a matching plug on the saw’s cord. Of course, if you end up with something less than a cabinet saw, you will probably only need 120 volts. But the cabinet saw is really nice if you can get there. Second best would be a hybrid. Third would be a contractor’s saw (with motor hanging out the back). Last would be a jobsite saw, with its little screaming universal motor.
But here’s a question for those more knowledgeable than I am about electricity: can the neutral wire from a dryer be used for the ground? I know that Square D panels combine ground and neutral on the same bus, but I don’t know about others.
Do check out KnottScott’s blog about table saws.
jonnybrophy
#13 posted 11-28-2016 02:31 AM
Thanks guys, I really appreciate the help. You really cleared some things up for me.
BorkBob
#14 posted 11-28-2016 02:40 AM
When I was a kid (and slave labor to my electrician step dad) most house wiring was two or three conductors. The 110 v circuits were a hot and a neutral and had no grounding conductor. The 220 v circuits were three conductors, two hots and a grounding wire. The neutral and grounding wires shared a buss in the panel.
Grounded 110 (later 120) v circuits came along in the early 60’s. 220 (later 240) remained 3 wire for a little longer. Because the neutral wire in 110 v circuits is current carrying when the circuit is in use, this meant the grounding wires sharing the same buss could be carrying current too. So, separate neutral busses and grounding busses were born and never the twain shall meet.
The third wire in the 220 v circuits used to be both a grounding conductor and a neutral for any 110 volt uses. Now it requires 4 wires.
dhazelton
#15 posted 11-28-2016 02:58 PM
Not an electrical-related answer but – I’ll go against trend here. If I were 18 again (sigh) and had $850 to spend I would upgrade the fence system on the saw I already had, then buy a nice router. And a nice sander. And a nice…..etc. You get the point.
