How to Cut a Pyramid Post Cap
Forum topic by SteveInVa posted 11-25-2016 03:52 PM 1381 views 0 times favorited 9 replies Add to Favorites Watch
View SteveInVa's profile
SteveInVa
29 posts in 1859 days
11-25-2016 03:52 PM
I need to make two pyramid post caps to match the one in the picture here. I have made the cap base, and I have the 3/4 inch piece of wood cut for the cap, but I need to put bevels on all four sides with a plateau on the top.
Can anyone tell me the safest way to do this? I appreciate any advice that you may be able to offer. Thanks.
-- Steve
9 replies so far
View Ron Aylor's profile
Ron Aylor
2125 posts in 550 days
#1 posted 11-25-2016 03:59 PM
I’ll let Paul Sellers explain … https://www.youtube.com/watch?v=MAezwdKjN2Y
-- Ron in Lilburn, Georgia.  Knowing how to use a tool is more important than the tool in and of itself.
View jbay's profile (online now)
jbay
2034 posts in 802 days
#2 posted 11-25-2016 04:09 PM
Professionals make things look easy!
-- If anyone would like to see my Portfolio, PM me and I would be glad to send you the link.
View mike02130's profile
mike02130
167 posts in 575 days
#3 posted 11-25-2016 04:12 PM
Just run it vertically though a table saw.
-- Google first, search forums second, ask questions later.
View Lazyman's profile
Lazyman
1677 posts in 1290 days
#4 posted 11-25-2016 04:24 PM
Another approach is to cut on the table saw. You tilt your blade for the angle you need and put the fence on the side of the blade so that the blade is titled away from the fence. You then slide the cap piece on edge so that it cuts a wedge out one the side away from the fence being careful to to keep the bottom of the cap flat against the fence. You will probably want to have a zero clearance insert depending upon the thickness of the cap and possibly an auxiliary fence to get some additional height for stability. You can practice on a piece of scrap before cutting the actual cap to make sure it comes out correctly.
View JackDuren's profile
JackDuren
388 posts in 862 days
#5 posted 11-25-2016 10:51 PM
Belt sander if you have one…
View Redoak49's profile
Redoak49
3075 posts in 1891 days
#6 posted 11-25-2016 11:47 PM
I would cut it on the table saw and use a tall sled that straddles the fence.
SteveInVa
#7 posted 11-26-2016 05:52 PM
Thanks everyone for the varied suggestions. I’m trying to build a sled for the TS; will post pictures and results . . . if it works.
-- Steve
SteveInVa
#8 posted 11-26-2016 06:00 PM
So, my jig worked pretty well. The jig consists of a sled and fence and three buttresses cut at 10 degrees. I attached the work piece with heavy duty double sided carpet tape, which held it firmly against the fence. The result is pictured below.
This is a slight modification from a jig in Ian Kirby’s the Accurate Table Saw. I like this jig because it prevents me from having to tilt my blade. Whenever I have tilted the blade on the my 30-year old Powermatic (Artisan 63) contractor saw in the past, I have had a devil of a time realigning everything when I bring the blade back to 90 degrees.
Thanks again for the suggestions.
-- Steve
View Cooler's profile
Cooler
299 posts in 746 days
#9 posted 12-02-2016 07:31 PM
I made a bunch of them. I screwed a length of stock to a board the same width and set my blade on an angle into a sacrificial fence and cut the entire length. I flipped over the stock to cut the opposite side.
I removed the stock from the mounting board and cut the stock into perfect squares. I then re-mounted the squares in tandem to the mounting board and made a angle cut and flipped over for the other angle cut.
I made about 6 or 8 at a time that way. It was many years ago and I may have forgotten some details, but it was fairly easy.
I arranged it so the pyramid came to a point.
-- This post is a hand-crafted natural product. Slight variations in spelling and grammar should not be viewed as flaws or defects, but rather as an integral characteristic of the creative process.
