1970's Craftsman Jointer
Forum topic by OleOlson posted 01-11-2008 05:33 AM 1362 views 0 times favorited 3 replies Add to Favorites Watch
View OleOlson's profile
OleOlson
3 posts in 3711 days
01-11-2008 05:33 AM
Topic tags/keywords: jointer
I recently aquired an older (1970’s) Craftsman jointer. The machining on the fence and tables is not the best. If you run your fingernail across it you can actually feel the machine marks. This is my first jointer and not sure if this is even an issue. I’m wondering if I should try and smooth it out some or should I just leave it alone and wax it up. If I try and smooth it what would be the best method. First post, great web site! Thanks in advance for any advice.
3 replies so far
View ChicoWoodnut's profile
ChicoWoodnut
904 posts in 3720 days
#1 posted 01-11-2008 05:47 AM
Hi Ole,
The most important thing about a jointer is for the tables to be parallel. If they aren’t you wont be able to make things flat. Put a straight edge on the outfeed table, roll the infeed table up until you can fit a playing card under the straight edge. See if the gap is the same on the left, right and all the way down the infeed side. You can do things to shim them square but it isn’t an easy exercise (tried it once, ended up with a boat anchor).
Good luck!
View GaryK's profile
GaryK
10262 posts in 3893 days
#2 posted 01-11-2008 05:50 AM
The machining marks shouldn’t make much difference as long as it is flat. I would not try to “fix” it
View Blake's profile
Blake
3443 posts in 3779 days
#3 posted 01-11-2008 06:21 AM
Gary is right, don’t “fix” it. Don’t worry about the machine marks. The important thing is that it is flat and parallel. As soon as you start removing metal, you will have a hard time keeping it flat. It shouldn’t effect the way it works anyway.
Don’t ever touch any cast table with anything but wood or steel wool it you want it to stay true. (No power tools!)
-- Happy woodworking!
