I need a picture of a delta table saw motor wired for 220
Forum topic by CTWith3 posted 11-24-2016 11:58 PM 840 views 0 times favorited 5 replies Add to Favorites Watch
View CTWith3's profile
CTWith3
26 posts in 980 days
11-24-2016 11:58 PM
Can somebody with a delta contractor saw please post a picture of their Delta contractor saw motor with the wiring cover off for me? I need to see the correct wiring because the gound on my motor seems to be mounted in the wrong place for 220.
Thanks!
(Yes I googled for an immage)
5 replies so far
View WhyMe's profile
WhyMe
1030 posts in 1612 days
#1 posted 11-25-2016 12:01 AM
What model Delta do you have?
CTWith3
#2 posted 11-25-2016 01:20 AM
Platinum 36-477
1 1/2hp/2hp motor
This same motor was used for many years
View MrUnix's profile
MrUnix
6824 posts in 2250 days
#3 posted 11-25-2016 01:23 AM
The ground wire should be connected to the metal frame of the motor somewhere (doesn’t really matter where), regardless of what voltage it’s setup for – 120v or 240v makes no difference.
CTWith3
#4 posted 11-25-2016 01:54 AM
Picture?
MrUnix
#5 posted 11-25-2016 02:01 AM
Picture?
- CTWith3
Of what exactly? A wire attached to the metal with a screw? How about YOU post a picture of what you got so we can see what you are talking about. A ground is a ground regardless of how the motor is wired, so saying it’s in the wrong place for a particular voltage doesn’t make much sense. Maybe you are confusing the ground with the neutral (which isn’t used for 240v)?
