Longevity of glued panels
« back to Joinery forum
Forum topic by Brettbuilds posted 11-24-2016 05:55 PM 509 views 0 times favorited 3 replies Add to Favorites Watch
View Brettbuilds's profile
2 posts in 480 days
11-24-2016 05:55 PM
Topic tags/keywords: glue panel longevity question
Hello all. Long time lurker, but first post. Probably a naive question, but here goes:
Someone asked me to make an urn for them. So, I got to sketching a design and picking wood. The design features different woods, so I’d make some small panels before joining them into the box. This got me thinking, what is the longevity of a purely glued joint, like a panel? Obviously this isn’t going be used like a cabinet door, but it might sit on a mantle for decades. Daily temperature fluctuations seem reasonable to expect- sunlight possibly, heat from a fireplace below the mantle, cool room temps at night- etc. Wouldn’t want the panels to de-laminate. So is there any guideline for how long a glue up might reasonably last?
Thanks much. Happy turkey day.
3 replies so far
View bbasiaga's profile
1158 posts in 1927 days
#1 posted 11-24-2016 06:27 PM
Forever? Modern glues are stronger than the wood they join, and waterproof once cured. I believe old time glue like hide glue was suseptible to temp and moisture and temp swings. But there are pieces 100years old out there that are still together.
View JBrow's profile
1340 posts in 852 days
#2 posted 11-25-2016 04:09 AM
What I believe to be comprehensive and authoritative resource for wood questions is the Wood Handbook published by the Forest Products Laboratory, USDA. It is available on-line and addresses a wide variety of wood related questions and issues, although at times it gets a bit technical. The chapter index is found at
For example Chapter 10 addresses adhesives. Your question is answered on page 10-21 under the caption Short- and Long-Term Performance. It confirms bbasiaga’s opinion for PVA glue, but with some conditions (namely that moisture content of the wood does not exceed 15% and the temperature range is kept within a range comfortable to people). This chapter is found at Performance of other glues is also included within the Short- and Long-Term Performance section.
2 posts in 480 days
#3 posted 11-25-2016 03:35 PM
Excellent. Thanks everyone.
