Broken brass screws. Aaaargghhh!!!!!!!
Forum topic by Chinitorama posted 1032 days ago 1721 views 0 times favorited 14 replies Add to Favorites Watch
View Chinitorama's profile
Chinitorama
105 posts in 1470 days
1032 days ago
Topic tags/keywords: question tip trick
Hi all,
Was just installing some Brusso hinges and the screws keep breaking. Brand new screws and one went in perfect in each leaf, so I think I’m stuck working with the leaf in place. Worse still, I tried to drill one out and the bit snapped off in the hole as well. Any suggestions as to how to get the bit out?
-J.
14 replies so far
View FlWoodRat's profile
FlWoodRat
732 posts in 2080 days
#1 posted 1032 days ago
J… sorry to hear about your dilemma. Been there done that. If you can back out the screw that went in well, you can remove the hinge leaf. Don’t tear up your wood trying to pull out the old screw. I’d suggest filing it down flush with your box then using some epoxy adhesive to hold down the hinge leaf. Screw in the good screw to ‘clamp’ it in place. Then get a nother screw, cut off the head and use CA glue to glue it above your screw up. LOL.. I couldn’t resist the pun. To prevent having to do this again, I suggest that you predrill AND use SS screws to cut threads into your wood. Remove the SS screws and replace with the brass screws. It would also be a good idea to use some screw lube…. beeswax is good. Good luck. Rat
-- I love the smell of sawdust in the morning....
View poopiekat's profile
poopiekat
2843 posts in 1905 days
#2 posted 1032 days ago
There are hollow bits you can buy that are specifically made to drill around a headless screw. Then you can plug the hole with 1/4” dowel. Use a vix bit with the proper diameter drill bit to make the new pilot hole.
View RogerBean's profile
RogerBean
757 posts in 1125 days
#3 posted 1032 days ago
I have lived in fear of this very situation for a long time, but have not had to deal with it. My inclination is as follows: If you have a Dremel or trim router, take a 1/8” straight bit and route a slot up to the broken screw without actually touching it (or maybe drill on both sides) so you can dig the broken parts out. Some sort of jig to get a clean cut would be preferable to freehanding it. The small router bit would then be able to cut a clean slot so you could make and glue in a snug-fitting plug. If you’re careful, you can make a nice clean job of it with everything covered by the hinge. If the same wood, it should be invisible. If it’s a quadrant hinge you have a bit more room to work and fit the plug.
Sounds like your drill may be a little too small. I also counterbore the top a little rather than try to force the unthreaded shank part into the wood. A little parafin or other wax on the screw also helps it go in easier. Some guys use steel screws to cut the initial bore and then install the brass ones.
I will be watching this post for any better ideas. This will probably happen to me tomorrow!
Good luck,
Roger
-- "Everybody makes mistakes. A craftsman always fixes them." (Monty Kennedy, "The Checkering and Carving of Gunstocks", 1952)
RogerBean
#4 posted 1032 days ago
Another thought, if you can see the broken shank you might be able to take a dremel and dental burr to cut a new slot. Then just back it out. I also like poopiekat’s approach with the special hollow drill. You will have to remove the leaves in either event.
Chinitorama
#5 posted 1032 days ago
Thanks guys,
Managed to back the good screws out and remove the hinge leaves. As the screws were brass, used a narrow chisel and mortised them out and plugged the holes. The broken drill bit I managed to squish out of the way with a nail set and plugged it as well. Poopiekat, I’ll definitely be buying a properly sized Vix bit tomorrow. Bottoms of the hinge mortises are a mess, but they’ll be covered in the end.
All in all it looks like the fixes will be invisible. I’ll post pics when the project’s done and see if anyone can guess which hinges were the nasty ones. :p
Thanks for the help everyone.
-J.
View Sawkerf's profile
Sawkerf
1776 posts in 1239 days
#6 posted 1032 days ago
When I’m working with brass screws, I use steel screws to “tap” the holes during fit-up. I only use the brass screws during final assembly – and NEVER use a power driver! – lol
View vicrider's profile
vicrider
168 posts in 1069 days
#7 posted 1032 days ago
maybe these
-- vicrider
View AaronK's profile
AaronK
1366 posts in 1635 days
#8 posted 1032 days ago
I installed hinges for the first time on my last project – beautiful extruded hinges and of course the screws were utter crap. I’d been forwarned of that, though, and took precautions:
1. drill the holes correctly
2. wax the threads
3. hand drive them slowly
and they worked totally fine – didn’t even need to pretap. your screws might be worse than mine, but i doubt it!
anyway, plenty of advice here on how to get the problems out… just take it really easy on those screws :-)
View Woodbutcher3's profile
Woodbutcher3
361 posts in 1058 days
#9 posted 1032 days ago
Stainles steel prep is a great method and wax is great advice. Some would even suggest soap. However, Let me say, soap attracts moisture – not good, especially if you go with screws other than brass or SS.
-- Rod ~ There's never enough time to finish a project, but there's always time to start another one.
View Gregn's profile
Gregn
1643 posts in 1154 days
#10 posted 1032 days ago
Have had this happen before. I took a piece of old brake line and with a triangular file cut teeth in the end of it. I then chucked it in my drill and drilled down to the depth of the screw and then popped it out like you would a plug.
View jsheaney's profile
jsheaney
141 posts in 2159 days
#11 posted 1032 days ago
Well, everyone has said all the important stuff. I’ve done the same thing myself. The thing that amazed me was how easy that screw head came off. Didn’t even feel it. So, my one little addition…hold the screwdriver with your thumb and fingertips. Don’t grip it with your whole hand. If you need more power than just your fingertips then your going to twist that head right off. Back it out and drill some more and do all those other things everyone said.
-- Disappointment is an empty box full of expectation.
3808 posts in 2193 days
#12 posted 1032 days ago
I use these Gimlets now to start the holes and follow them with a steel screws then the brass ones.
Got mine from Lee Valley.
View Jim Jakosh's profile (online now)
Jim Jakosh
7323 posts in 1276 days
#13 posted 1022 days ago
Wow you all had some real good ideas. The hollow bit and plug was my choice, but I think prevention is a key for all of us . Centering hinge holes with a Vix bit and drilling a pilot hole of the proper size is a must, but I like”tapping” the hole out with a same size steel screw first. I learned something new today again!!!!
One error I found out on Vix type bits. Always check to see that the tapered sliding portion of the Vix bit does NOT protrude through the hinge . If it does, It will not center the screw. It will go where that end first hits the wood. If it does stick through, remove the drill bit and carefully grind off just enough of the end of that tapered section so it is not sticking through. This will let the taper find the “pocket” and truly center the drill.
-- Jim Jakosh.....Practical Wood Products...........Learn something new every day!!
View Greg The Cajun Box Sculptor's profile
3779 posts in 1479 days
#14 posted 98 days ago
I like the solid brass hinges but the brass screws are not good and anyway you look at it brass is soft…
I now discard the brass screws and use #4 steel brass-plated flat head screws with a square drive instead of a philips head…
I use the vix bit all the time and it is great. I have also used the screw extractors that drill around the hole but have fortunately not had that problem in a long time.
-- Every step of any project should be considered your masterpiece if you want the finished product to reflect the quality of your work. http://www.FineArtBoxes.com
