Need to build an adjustable table for building cabinets
Forum topic by Rdefino posted 11-23-2016 03:55 PM 694 views 0 times favorited 6 replies Add to Favorites Watch
View Rdefino's profile
Rdefino
2 posts in 695 days
11-23-2016 03:55 PM
Hi there, I’m looking to build some cabinets. But I need a table to build them on that has wheels and I can adjust the height of the wheels to make it level. Floor I’m working on isn’t that level. Looking to have the table only about a foot of the floor.
That’s for any ideas.
View Loren's profile
10477 posts in 3794 days
#1 posted 11-23-2016 04:26 PM
Make it with 3 legs.
#2 posted 11-23-2016 04:30 PM
You can can get adjustable furniture feet from
Ikea and other sources, too. I don’t recall ever
seeing an adjustable foot with a caster mounted
on it.
Some mobile machine bases have adjustable feet
that lift the wheels off the ground, thus immobilizing
the base and adjusting to an out-of level floor at
the same time. You might study some of those
designs… I have a ShopFox one that’s like that.
#3 posted 11-23-2016 04:33 PM
Another way to do it is a large square/rectangle
frame with straight locking casters at two corners
and a third swiveling caster mounted opposite
in the center so there are 3 mobility points.
Leveling feet are added to the 2 other corners.
Some mobile machine bases use this idea.
Rdefino
2 posts in 695 days
#4 posted 11-23-2016 09:35 PM
Loren,
thanks for the ideas. I like the Fox shop product. Might look at one of them.
thanks
View JBrow's profile
JBrow
1366 posts in 1066 days
#5 posted 11-24-2016 02:03 AM
Rdefino,
Amplifying Loren’s comments, leveling castors could be an option. These are castors with the ability to adjust the castor for uneven floors and could probably bring the work surface to level.
https://www.google.com/search?q=leveling+castors&ie=utf-8&oe=utf-8#q=leveling+casters&tbm=shop
View cracknpop's profile
cracknpop
326 posts in 2495 days
#6 posted 11-25-2016 01:08 AM
Some good suggestions above. Here is another concept a couple LJs used to address similar issue with their table saw carts.
http://lumberjocks.com/projects/97887
http://lumberjocks.com/projects/54805
-- Rick - I know I am not perfect, but I will keep pressing on toward the goal of becoming all I am called to be.
