Temporary wiring to shop
Forum topic by prad posted 11-23-2016 02:53 PM 611 views 0 times favorited 17 replies Add to Favorites Watch
View prad's profile
prad
15 posts in 866 days
11-23-2016 02:53 PM
Topic tags/keywords: electrical
Not sure where to post this.
I’ve found I need to run 220 to my shop to give my planer and tablesaw the juice they need. I’ve got em wired for 120 but that pulls too much amps from the measly circuit. I’m planning to wire a 220 circuit from the house and get it over to the attached shop. Unfortunately winter is here and I don’t think its going to work to get it properly trenched in this year.
My question: Would it work to simply have the wire laid across the ground between the house and the shop (just until spring time)? I’d appreciate any feedback.
17 replies so far
View JCamp's profile
JCamp
877 posts in 749 days
#1 posted 11-23-2016 03:19 PM
My two cents….. yes it will work. Electric is kind of like water it flows where the load is. That being said I personally wouldn’t do it. I don’t know how far ur planning on going but around my home me or someone else always has a vehicle, mower, tractor, fourwheeler in the yard. To me I wouldn’t chance it. The wire insulation could get a hole in it an ground out of u get snow or rain or shock the unsuspecting person that’s dumb enough to stand on it.
Would u happen to have a 220 generator that could get u by until spring?
Do u hav a friend or neighbor with a tractor an a plow that could dig u a ditch? Technically the ground is only frozen a foot or so down
Can u hide a temp fix from ur insurance company/city inspector or snoopy neighbor?
If u do decide to do it make sure u talk to someone and verify that the wire insulation won’t break down over time since it will be exposed to the elements. Ideally it would b the same direct bury (assuming ur going under ground an not over head) that u can reuse for your permanent wiring this spring.
Just my two cents. Be safe
-- Whatsoever thy hand findeth to do, do it with all thy might
View GR8HUNTER's profile
GR8HUNTER
5099 posts in 911 days
#2 posted 11-23-2016 03:25 PM
picture would help a lot ….but if its attached can you run it in attic ....... where is main panel ? is there room in it ???
View B4B's profile
B4B
163 posts in 1556 days
#3 posted 11-23-2016 03:50 PM
You mention trenching, but then say is attached.
If attached can you run the wire inside the house or use THHN wire in a conduit along the outside of the house?
If it’s detached could you install one or two in-use 120v recepticals, each on a dedicated branch circuit on the outside of the house then get and get a pair of quality 10 or 12 gauge extension cords of sufficient length to run to the shop when you are using the tools and coil it up when not in use. Keep in mind voltage drop over longer runs (100 feet comes to mind) may require a thicker wire (10 awg vs 12 awg for a 120v circuit, regardless of amperage).
Also, you’ll have to check electrical code, but I think you can only have 2 branch circuits going to any given out building/auxiliary structure before you have to install a sub panel, not sure sure specifically of the requirement.
If it were me, hire an electrician and do it right, meet code and ensure proper permitting.
-- There's two routers in my vocab, one that moves data and one that removes wood, the latter being more relevant on this forum.
View prad's profile
prad
#4 posted 11-23-2016 03:56 PM
Sorry for the confusion, I meant to write detached shop.
View prad's profile
prad
#5 posted 11-23-2016 04:07 PM
My two cents….. yes it will work. Electric is kind of like water it flows where the load is. That being said I personally wouldn t do it. I don t know how far ur planning on going but around my home me or someone else always has a vehicle, mower, tractor, fourwheeler in the yard. To me I wouldn t chance it. The wire insulation could get a hole in it an ground out of u get snow or rain or shock the unsuspecting person that s dumb enough to stand on it.
If u do decide to do it make sure u talk to someone and verify that the wire insulation won t break down over time since it will be exposed to the elements. Ideally it would b the same direct bury (assuming ur going under ground an not over head) that u can reuse for your permanent wiring this spring.
- JCamp
I’ve exhausted all my favors for the year. The span between the house and shop is about 15 foot, so not too bad for hand trenching.
Ya I was really worried about breakdown of the wire, I don’t think it likes to be stepped on and is not resistant to the elements.
If it s detached could you install one or two in-use 120v recepticals, each on a dedicated branch circuit on the outside of the house then get and get a pair of quality 10 or 12 gauge extension cords of sufficient length to run to the shop when you are using the tools and coil it up when not in use. Keep in mind voltage drop over longer runs (100 feet comes to mind) may require a thicker wire (10 awg vs 12 awg for a 120v circuit, regardless of amperage).
Also, you ll have to check electrical code, but I think you can only have 2 branch circuits going to any given out building/auxiliary structure before you have to install a sub panel, not sure sure specifically of the requirement.
- B4B
Here is my revised idea. Wire a 220 receptacle to the side of the house facing the shed and then make an extension cord long enough to get to my shop tools. I found this wire that appears to be good for making weather resistant extension cords: https://www.wireandcableyourway.com/10-3-sjoow-portable-cord-300v-ul-csa.html? . I think if I did it this way it would more safe. I could just unplug the extension cord and drag it into the shop. Next year I can get it done properly.
How does that sound to everyone?
View prad's profile
prad
#6 posted 11-23-2016 04:14 PM
BTW the motors on the tablesaw and planer both draw 24 amps at peak (wired for 110). I don’t currently have a 30 amp 110 circuit in the whole house aside from some dedicated appliances, so running a 110 extension cord from somewhere is a no go with adding a new circuit. I’ve managed to run the tablesaw by takin it easy while cutting but now I’m routinely kicking the breaker. The planer won’t fully power up before it kicks the breaker.
View rwe2156's profile
rwe2156
3168 posts in 1679 days
#7 posted 11-23-2016 04:19 PM
- prad
Perfect!!
5172 posts in 2691 days
#8 posted 11-23-2016 04:21 PM
Can’t add much to what has been said, but if it’s only 15’ it sure looks like you could get it under at least a little dirt until spring. It doesn’t have to be buried very deep to be safe until spring, and leave a little slack at one end to put it deeper. Your extension cord idea is better than leaving the Romex on top of the ground, I’d go that way if you absolutely can’t bury the feeder.
JCamp
#9 posted 11-23-2016 04:31 PM
I second what Fred said. Cord is a much better idea than a “hot” wire just laying on the ground but even if u just buried it a foot that should b about enough for permanent installation unless u live where codes r a factor. Digging would also depend on where u r located Im in Ohio an it’s been freezing at night but warms up in the afternoon so I’d still b able to dig that deep without much issue.
I will say that if u are going to go ahead and wire a 220 outlet on ur house go ahead an get a nice big breaker for it so that in the event that you’d ever need to plug into a generator to power the house you hav a good start (might b a plus if u go to sell it later). Not sure if that’s a common issue for most of u but I’ve ran my generator for days waiting for the power company to get the power back on.
Whatever u do just be safe
View prad's profile
prad
#10 posted 11-23-2016 04:34 PM
Burying it really is a hassle this year not just because the ground may be hard. There is a brick patio that would have to get pulled up and wood stairs going down to that patio would also be in the way.
View fivecodys's profile
fivecodys
1222 posts in 1834 days
#11 posted 11-23-2016 05:10 PM
You could run the cable through some PVC conduit to bridge the gap and then lay a few landscaping pavers over the conduit to keep it from being movers around during the winter.
Just my 2 cents.
-- I always knew I would grow old, But I expected it to take longer!
View MrUnix's profile
MrUnix
7038 posts in 2397 days
#12 posted 11-23-2016 05:16 PM
That SJOOW cord should be fine… SJ = Hard Service, OO = both inner and outer jackets are oil resistant and W = weather resistant (ie: Outdoor rated). A better choice would be SOOW, which is extra hard service (SJ is just hard service), and going with a 4 conductor wire would allow you to split off 120v circuits if needed since it will carry the extra neutral line for that purpose. Additionally, if your machines are rated 24A@120, then they will only need 12A@240V, so 10ga is a bit oversized… a 12/4 should be more than adequate and a bit cheaper… here is a 25 foot roll of the stuff at the BORG for about $30. Add a plug/outlet and you will be good to go. Remember, you will also have to re-wire and change the plugs on your machines as well, so get them all at the same time.
View prad's profile
prad
#13 posted 11-23-2016 05:26 PM
- MrUnix
Thanks Brad,
I’m not sure why I’d need “extra-hard” I had thought that was for higher voltage. Could you elaborate?
I’ve got 20 amp 120 service to the shop currently, so I don’t think I’ll need to split this off into 120. 20 amp is plenty for all my light duty stuff and lighting. Anything that will pull a lot I’ll get it to run off the 220 service.
View Lazyman's profile
Lazyman
2609 posts in 1585 days
#14 posted 11-23-2016 05:33 PM
You may also be able to just buy an extension cord for an RV that will work. They tend to be a little pricey but at least you will know it designed for outdoor use, running across the ground, where people might step on it.
MrUnix
#15 posted 11-23-2016 05:41 PM
- prad
You don’t absolutely ‘need’ it… SOOW just means it has thicker jackets and can be subjected to more abuse than SJOOW… hence it’s rated for ‘extra hard service’ instead of just ‘hard service’. You also don’t absolutely need 4 wire cord if you are going to run strictly 240v, but having the capability for future use might be something to think about. You are making an extension cord – might as well make it as robust and flexible as possible :) Just some stuff to consider.
