Shelf pins...
Forum topic by jonlan posted 11-23-2016 02:47 PM 1130 views 0 times favorited 15 replies Add to Favorites Watch
View jonlan's profile
jonlan
57 posts in 1008 days
11-23-2016 02:47 PM
Hi all. I’ve been working on a new set of built-ins for our upstairs loft and so far I’ve been really pleased with how they’ve turned out! This is my first cabinet project so I was a little hesitant to jump into something this big but so far things have been going great. Until today…
The built-ins consist of two base cabinets on either side of a window that are connected by a window bench underneath. Then on top of the book cases I added bookshelves all the way to the ceiling. I just got done with the last book shelf last night and I’ve run into a problem. My wife wanted adjustable shelves so I went and bought wood peckers shelf pin jig. I spent a lot of time practicing on scrap pieces of wood to make sure I understood how it worked and what to look out for. I decided to use the router method to make sure the holes were straight up and down (im not great with drilling perfectly straight by hand). Then I did the first bookshelf which turned out great. However, I just got the face frame on the second bookshelf and tested some of the shelves to find out that one of the sets of pin holes is off! I can’t believe it. 3 of the columns of pin holes are dead on but the 4th is off by about an eighth of an inch on every hole.
So at this point, Im not quite sure what to do. I would guess that somehow the first hole I drilled got off and when I used that as an index hole for the others they all turned out off. In either case, the bookshelf looks great and I cant imagine scraping it to rebuild it. Part of me was hoping that they might make something like an adjustable shelf pin but that doesnt seem to be a thing. I guess I could find a way to make that pin slightly larger but that might stand out (its the back set of pins, if it was behind the face frame I wouldnt care). Redrilling the holes seems like an option but filling in that many holes with putty and having it not show up through the paint seems like something that wouldnt work out the way I had hoped. Anyone run into this before and had a creative solution that I hadnt thought of yet? :)
15 replies so far
View paratrooper34's profile
paratrooper34
915 posts in 3073 days
#1 posted 11-23-2016 02:55 PM
You have a router, so this is doable for you: rout out a groove, 1/2” wide is enough and as deep as your shelf pin holes are. Then you can fill in the groove using a properly sized piece of the same wood. Once glue is set, do your shelf pin jig again. Much easier then trying to drill a hole 1/8” next to the old one.
-- Mike
View jbay's profile (online now)
jbay
2604 posts in 1020 days
#2 posted 11-23-2016 04:36 PM
If your face frame overlays enough, slap in a new side piece with the new holes already drilled in it.
(and cut the shelves down)
If the off row of holes is higher than the rest, you could rout a small space (just big enough to accommodate the pin)
and let the shelf sit down over the pin a little.
jonlan
#3 posted 11-23-2016 04:47 PM
@jbay. Boy is that a good idea. I think when I build book shelfs in the future I’ll do the holes in a quarter inch strip of wood just incase this happens again. That way I could remove it if needed or shift it slightly. Then I would just need to notch out the shelves for the strips. I think for now I’m going to try to move to ‘L’ type brackets and just put a spacer on top of the bracket. Not ideal, but if I use a clear spacer and the cabinet and shelf is all white I wonder if you wont notice it.
Thanks for the tips, these are all good ones.
View jerryminer's profile
jerryminer
944 posts in 1562 days
#4 posted 11-24-2016 08:36 AM
A small bumper stuck to the bottom of the shelf at the pin location would do it
View Redoak49's profile
Redoak49
3455 posts in 2110 days
#5 posted 11-24-2016 12:26 PM
It is a good idea to measure and mark where the holes go at least in a couple locations so you do not make such a mistake.
I did a zillion holes like that when a built my shop cabinets. I built my jig so that it was very difficult to make a mistake.
View bilyo's profile
bilyo
308 posts in 1224 days
#6 posted 12-01-2016 02:47 AM
jonian, I think that your idea of using the spacer is probably the easiest and quickest. However, you could also try something like this:
http://woodworker.com/spiral-support-shelf-pins-mssu-156-191.asp
View Cooler's profile
Cooler
299 posts in 964 days
#7 posted 12-02-2016 07:25 PM
I cut a piece of peg board to the exact size of the verticals. I use masking tape to tape off the holes I don’t want to drill.
I put the piece against the side and clamp. I use 5mm Vix bits to drill.
I then switch sides by sliding the peg board across to the other side (don’t flip the board).
These have to be “eyeball vertical” not perfectly vertical in order to function correctly.
I find that this method makes it quite impossible to get mis-aligned holes. The vix bits drill cleanly. I use 3/16” peg board.
-- This post is a hand-crafted natural product. Slight variations in spelling and grammar should not be viewed as flaws or defects, but rather as an integral characteristic of the creative process.
View Loren's profile
10477 posts in 3769 days
#8 posted 12-02-2016 07:39 PM
Consider plugging the holes with filler or dowels.
Make a 1/4” thick veneered ply cover piece
with pin holes in the correct pattern, then
nail that in and use the holes as drill guides
to deepen the shelf pin holes.
View MT_Stringer's profile
MT_Stringer
3173 posts in 3352 days
#9 posted 12-02-2016 07:53 PM
I vote to shim the pin that is off and let it go at that.
Or, fill the holes and sand them smooth, redrill.
I like the idea of a shim. No one will ever know except you, your sweetie, and several hundred of us! LOL
MT_Stringer
#10 posted 12-02-2016 08:01 PM
Just a note…
There are many ways to drill shelf pin holes. I have used a template and a router before with good success.
But for me, and the work area I have, the Kreg shelf pin jig works well. I have two attached together with the included attachment.
Spacers are your friend. Do it right and everything will turn out right. And don’t forget the mirror image on the opposing side. I have made that mistake before.
I just finished building 14 cabinets for two small kitchens. Every one turned out great with no wobble on any of them.
Good luck. Post some pics.
Here are a couple of pics of my way of doing it.
18869 posts in 1978 days
#11 posted 12-02-2016 08:04 PM
There are numerous styles of shelf pins available. You may be able to find a style that is different by the right amount that you could use those on ones side and level up the shelves.
View Holbs's profile
Holbs
1935 posts in 2150 days
#12 posted 12-03-2016 01:47 AM
If shelf pins are in your future for things… lots of jigs out there that work 2 dimensional. I snagged something spectacular. The Veritas Cabinet Making System. You can’t mess up any alignment on this thing as you can rotate boards left & right and top & bottom as they are mirror images with this jig. Though..it comes with a price tag.
-- The Carpenter Bee is derived from the Ancient Greek word wood-cutter
View Steve's profile
Steve
188 posts in 2121 days
#13 posted 12-03-2016 02:33 AM
My General 13 Spindle boring machine, makes drilling cabinets a breeze.
jbay
#14 posted 12-03-2016 03:18 PM
- Steve
Pffft….
My Ritter 42 Hole, Double Row. Now that makes drilling cabinets a breeze. lol
View bondogaposis's profile
bondogaposis
4931 posts in 2472 days
#15 posted 12-03-2016 04:04 PM
Use shelf pins like this and add a wood shim on the one pin that needs it.
-- Bondo Gaposis
