| Forum topic by Mark A. DeCou | posted 1213 days ago | 902 views | 0 times favorited | 3 replies | ![]() |
1213 days ago |
Hey Fellow Lumberjocks: However, what does a lumberjock do when they are faced with making up the dimensions of a project by their own choice? How big should the Hutch be on a China Hutch in comparison to the base unit? How many doors should flow across an entertainment center? Have you ever made something that seemed the right size in the shop with the high ceiling and wide wall space, only to look monstrous in your bedroom? Another “for instance” could be: should all five drawers on a tall dresser be the same size, or would it look better if they were proportioned differently? Making all the drawers the same size sure speeds up production, but is there an overriding principle that is more pleasing to the human eye, that high-speed production efficiency leaves out? I am starting to think that there is. For instance, the thing that bugs me about modern kitchens, is that it is just row after row of repeating squares and rectangles, all the same size so that the factory could make them efficienctly. I don’t know how to do it differently, but maybe somebody out there has been pondering this already, and has some ideas for me. Obviously, there are many factors involved in what size something we build should be. First, in my mind, we should consider the ergonomics, or the process of fitting the human body to the item being used by the body for support or work. Modern sculpture can be of any size the artists envisions. But a chair, must first fit the body it is intended to support, or it is not a chair, in my mind. Second, there is tradition, or the underiding power of familarity, the love and feeling for what has been done in the past, that the human eye accepts as “correct” due to it’s previous common exposure. Sort of like thinking about the “common knowledge” feeling we get about subjects most of us know something about. Then, there seems like there must be some space and weight limits. How tall, or wide something is to be built must surely depend somewhat on how the item will be moved and carried, or fit through a door, or up a stairway. I once made a one piece entertainment center that would take a piano moving crew to move. I only delivered it with 3 other friends helping me. In my mind, that was not good design on my part, eventhough I thought of including hand hold holes in the back of the cabinet. Today, I try to build things in smaller sections, each piece able to be moved by reasonably strong adults. But, am I just trying to be too practical? I would like your input. Maybe I am just all “wet” here because my back is sore from moving a heavy thick slab dining table top I’m building in my shop by myself lately. Or, here is another question: am I losing some of the “art” when I worry about engineering problems like this? But, here is the point that I was hoping to get to: I have been using the “Golden Rectangle” formula for almost all of my work in the past 3 years or so, and I think it just looks better than the work I used to do. The “Rectangle”, for those that don’t know, is a ratio of repeating rectangles, all related to each other through a mathematical formula. These same ratios are found in nature in repeating forms also. According to the article I read, this ratio has been used throughout human history, and has just been seen as good design whether for buildings, pyramids, skyscrapers, or dresser drawers. What are some of your thoughts on proportion, sizing, and deciding what length to cut the first board of a new project? I would like to learn from you all, making my work better. Thanks, -- Mark DeCou - American Contemporary Craft Artisan - www.decoustudio.com |
