I'm just starting spraying lacquer
Forum topic by Jeff_in_LSMO posted 11-21-2016 11:34 PM 694 views 1 time favorited 8 replies Add to Favorites Watch
View Jeff_in_LSMO's profile
Jeff_in_LSMO
352 posts in 2489 days
11-21-2016 11:34 PM
Topic tags/keywords: spray lacquer
I have questions. I am familiar with spraying paint, but not lacquer. How should it look when it is wet? How do I know if I have sprayed enough?
Please include pics or references.
8 replies so far
View mrbob's profile
mrbob
182 posts in 717 days
#1 posted 11-21-2016 11:53 PM
I hope you are aware of lacquers volital rate.
View the_other_ken's profile
the_other_ken
37 posts in 3124 days
#2 posted 11-22-2016 12:19 AM
Get a mil gauge. The lacquer manufacturer will tell you how many mils to apply for each coat as well as total recommended thickness.
View pintodeluxe's profile
pintodeluxe
5758 posts in 2962 days
#3 posted 11-22-2016 12:41 AM
With a 1.5mm tip and a gravity feed gun, it is pretty easy to lay down a nice wet coat. Too thin / too quickly applied will give you orange peel. Too thick / too slowly applied will give sags or runs on vertical surfaces. Whenever you can, lay panels and cabinet doors flat, for the best results.
Thin the lacquer 10-15% with lacquer thinner, and practice on some scraps. Most novice sprayers move the gun too quickly. Slow down and spray in an overlapping pattern. Use a low angle work light and use the sheen you see to guide your progress.
Jeff_in_LSMO
#4 posted 11-22-2016 12:58 AM
what sheen am i looking for? should it be smooth? i’m worried i’m putting it on too heavy.
mrbob
#5 posted 11-22-2016 01:04 AM
what sheen am i looking for? should it be smooth? i m worried i m putting it on too heavy.
- JeffinLSMO
Jeff Jewitt has a great book on spraying and also comes with a DVD, soft cover at amazon is less then $30 if I remember right.
View Carey  Mitchell's profile
Carey Mitchell
120 posts in 2107 days
#6 posted 11-22-2016 02:31 AM
I started by just spraying some old furniture, using various settings, etc. I don’t have a professional sprayer, but a HD general purpose type, as well as a touchup sprayer from HD. I would tape off sections and try different approaches; when dry, use remover , give it time to dry and try again.
One thing I love about lacquer is blending semi-gloss and satin 50/50 to get a luster level that I like (see some photos: http://lumberjocks.com/crmitchell/projects).
I don’t always get the result I am looking for the first try,but paint remover is plentiful. One comment above showed a mil gauge and suggested a spec sheet – here’s the one for PPG products that I use – http://buyat.ppg.com/rep_pafpainttools_files/Pghpaints/tdb/77-9110.pdf
One note about air temp. My first try was on a July 4 holiday and the temp was about 98. It was so hot the solvent was drying mid-way to the wood, and it all turned white, enter remover and start over. In this situation, you switch to retarder, but don’t expect to find it at HD or Lowes, as they have never heard of it. Mine came form the local PPG store. I don’t like it and don’t use it if possible because of the odor.
Speaking of odor, avoid the brushing lacquers, as the Delft products are terrible and it takes about a week for it to dissipate, during which it cannot come in the house !!! (unless you like sleeping in the yard with your project)
pintodeluxe
#7 posted 11-22-2016 02:58 AM
A nice shiny wet coat. It’s easier than you think.
View CheeseSteak1's profile
CheeseSteak1
10 posts in 698 days
#8 posted 11-28-2016 05:57 AM
https://www.youtube.com/watch?v=V7mZbA3nkc0
This video helped me out earlier this year I hope it does the same for you.
