Gluing on a waste block
Forum topic by Raftermonkey posted 07-25-2010 03:29 AM 1322 views 0 times favorited 3 replies Add to Favorites Watch
View Raftermonkey's profile
Raftermonkey
560 posts in 3111 days
07-25-2010 03:29 AM
Topic tags/keywords: waste block glue question trick tip lathe turning bowl
I have turned the outside of my first bowl. Its pretty small. I think I am going to glue on a waste block to turn the inside. I have read a liittle bit on here about sandwiching a brown paper bag between the waste block and the bowl. I have also read about using sheetrock in the same manner. What do ya’ll think, and what kind of glue would be best?
Thanks,
-- -Zeke- "I hate to rush off, but I gotta go see a man about a log"
3 replies so far
View schloemoe's profile
schloemoe
709 posts in 3137 days
#1 posted 07-25-2010 04:30 AM
I saw Norm do it with just regular peice of paper…...............................Schloemoe
View Paul2274's profile
Paul2274
330 posts in 3311 days
#2 posted 07-25-2010 05:08 AM
I turned a lot in high school and I always just used a piece of plain white paper. When your done, if you bottom isn’t to thin, just use a sharp chisel and work around the bottom gently and it will finally come right off and then just sand the paper residue off.
Good Luck,
Paul
View lew's profile
lew
12426 posts in 3954 days
#3 posted 07-25-2010 06:30 AM
I use a paper bag and titebond II
