Scraper Plane or Hand held Scraper Blades... ? which do you prefer?
Forum topic by patrick miles posted 318 days ago 315 views 0 times favorited 10 replies Add to Favorites
View patrick miles's profile
patrick miles
131 posts in 341 days
318 days ago
Topic tags/keywords: tip resource question trick
Hello again guys n gals. Fellow woodchuck’s… I’m looking at buying a scraper plane or Blades w holder that need no plane body. I’m curious which works better for any of you .?. Up until now I plane my projects with block plane or smoother and or sand. Thinking a scraper plane will give me ‘clear’ true to the grain outcome…? I have my finishes down and a huge list of many different types including french polishes, thanks to you guys.. Well ,any advice about scraper planes or your ways of fine tuning your wood before adding a finish.. Thanks a million, patrick Miles aka woodnut99.
-- PJM.`·.¸¸.·´¯`·.¸¸.·´¯`·.¸ ><((((º> why's there a light in fridge and not the freezer? , aka, the wood hunter.aka tigermaple5
View rikkor's profile
rikkor
8362 posts in 403 days
318 days ago
I have a Stanley #80 scraper and a card scraper. I use the card scraper about 3 to 1 over the 80.
-- Maplewood, MN
View Marco Cecala's profile
Marco Cecala
43 posts in 561 days
318 days ago
Glad to hear things are going well in your quest for better projects. My thoughts on the tools you reference are these…
Any blade that is held in a body is meant for more aggressive stock removal. I like the Stanley 80 and equivalents for a transition from planing to finishing.
Nothing beats a well tuned card scraper for final smoothing, as well as removing nubs after grain raising.
Fine woodworking did a test, and found that there is no difference in the look of a finish when the wood was prepared by planing/scraping or sanding. Use both methods as you see fit for the task at hand.
View JJackson's profile
JJackson
80 posts in 611 days
318 days ago
Patrick,
I was in the same boat awhile back as you are in now. I asked the same questions and did some research. I ended up buying the LN Large Scraper Plane. Wow, what a great plane. It was polished, well fitted, and easy to adjust. The only problem, I couldn’t get the darn thing to work properly. So off to Ebay it went. I use the hand scrapers now and they work quite nice for me. By the way, I have 15 planes that I use on a regular basis, I just couln’t get the hang of the scraper plane.
If I were going to buy a scraper plane again and give it a go, I would definately buy the Veritas Scraper Plane. On the Veritas, you are able to “bow” the blade making it easier to use. Thats just my 2 cents.
-- Jeff, Indiana
View Harold's profile
Harold
294 posts in 376 days
318 days ago
I would also go with the hand scrapers, you can reach so many more areas than you can with a plane or 80. I do have the Veritas scraper plane which is a very well made functional plane, but it is heavy. A simple scraper in your shirt pocket is impossible to beat, saves sand paper and saves time.
-- If knowledge is not shared, it is forgotten.
View GaryK's profile
GaryK
8541 posts in 517 days
318 days ago
Hand scrapers are nice in that they can do more than just flat surfaces. You can get a goose neck
scraper for curved surfaces. You can also get a lot more control over just where you want to scrape.
Plus they are cheap.
View Derek Cohen's profile
Derek Cohen
22 posts in 497 days
315 days ago
Scraper planes and card scrapers do different things.
I love using a freshly honed card scraper for those small, difficult-to-reach or just tiny areas. The ability of such a simple tool to produce such amazing results is a constant wonder.
There is a danger in the indescriminate use of a card scraper, however. When pushed, the steel bends and this camber can/does plane grooves into the surface. This may only become apparent when the finish is applied. On the other hand, this camber can be useful for digging out deep tearout. For these reasons it is helpful to learn to pull the card scraper as well as push it. I even hone up the short ends of the cards as these are stiffer.
A scraper plane (I have a Stanley #112 with LN blade) is preferred when one has large areas of interlinked wood to smooth, and the smoother just not hack it. I have some amazing smoothers that can plane just about anything, but not even these can plane everything! A well set up scraper plane is capable of smoother-like performance that cannot be matched by a card scraper.
Horses for courses.
Regards from Perth
Derek
-- Building and Reviewing Tools at http://www.inthewoodshop.com
View Chris 's profile
Chris
1259 posts in 519 days
315 days ago
I have yet to try a Scraper plane. But I do use my card scrape a fair bit; i just wish it did not lead to burned thumbs…. Boy does it get hot!
-- Chris
View Thos. Angle's profile
Thos. Angle
3409 posts in 491 days
315 days ago
I have card scrapers, a #80 and a cheap 112 clone. I use them all for different things. I also sand with a random orbit and finish by hand. If you finish with a film finish you can’t tell the difference.
patrick miles
314 days ago
Wow Thank you all so very much.. I’m so happy with the great info … Looks like I’ll be trying both, blade and plane scraping.. Derek those pictures of your 112 in action are GREAT ! Thank you they give me hope and inspiration with my quest for a fine finish…
View Greg3G's profile (online now)
Greg3G
666 posts in 614 days
314 days ago
I too use both the 80 and card scrapers. One thing that I did on the 80 was I put a 45 on one side of the blade. I use that side when I need to get agressive on something, like a rough area on figured Maple. I can quickly remove rough saw marks down and then flip the blade smooth it then pick up a card scraper to finish. It works very well for me.
-- Greg - Charles Town, WV
Bookmark And Share This Page
