Rewiring 1 3/4 HP Table Saw for 220V
Forum topic by cag0331 posted 11-21-2016 03:02 PM 927 views 0 times favorited 5 replies Add to Favorites Watch
View cag0331's profile
cag0331
13 posts in 605 days
11-21-2016 03:02 PM
Topic tags/keywords: table saw 220v wiring electrical awg wire gauge
Hello everyone. I have a 1 3/4 HP Laguna Fusion Table Saw that is currently wired for 110V. I just had a 220V circuit added to my shop and want to rewire the saw to use that circuit as I have had some issues with tripping breakers (previously all the receptacles in my shop were on the same circuit). When I contacted Laguna to ask what I would need to do this, they sent me a new switch and motor reset button. My question, though, is whether the wire that came on the new switch is substantial enough. It has SJT 14/3 running from the switch to the motor and from the switch to the plug. Is this acceptable?
I’m considering replacing the wire to the plug with something longer and was thinking I might need to move a gauge or 2 up. Any thoughts?
Thanks!
5 replies so far
View eflanders's profile
eflanders
301 posts in 1876 days
#1 posted 11-21-2016 03:40 PM
The wiring inside the switch is 14 ga.? If so, yes it is fine. If the wire from the switch to the motor and from the motor to the plug that too is fine. But you will want at least 12 ga. wire going to the saw from the circuit. Wire gauge is based a lot on length of run.
cag0331
#2 posted 11-21-2016 03:48 PM
The motor connects to the switch, which then connects to a plug which would be plugged into the circuit. All the wiring to and from the switch came as 14 gauge. Maybe just replace the wire from the switch to the circuit with 12 ga. especially if I’m making a longer run?
18351 posts in 1882 days
#3 posted 11-21-2016 03:54 PM
The longer run only applies to the distance from the breaker to the receptacle. That wire needs to be 12. For the other short distances, the 14 is fine. Remember that you only have half the amps per leg now as opposed to 120. You can feed the 14 with 12, but not the other way around.
View verdesardog's profile
verdesardog
161 posts in 2637 days
#4 posted 11-21-2016 05:27 PM
#14 wire is rated for 15 amps…..Full load amps for 220v 1 1/2 hp motor is about 10.
The manufacturer wouldn’t have sold anything less than what is required and probably not anything more than what is required.
-- .. heyoka ..
View REO's profile
REO
928 posts in 2099 days
#5 posted 11-21-2016 11:48 PM
For the appliance cord 14 gage is good for 18 amps and 12 gage is good for 25 amps for up to 50 feet
