Porter Cable table saw
Forum topic by oktams posted 11-21-2016 02:46 PM 528 views 0 times favorited 0 replies Add to Favorites Watch
View oktams's profile
oktams
6 posts in 968 days
11-21-2016 02:46 PM
Topic tags/keywords: porter cable table saw blade raise question worm gear sled
I have a Porter Cable Jobsite table saw…everything was fine, then it wasn’t ugh I cant get the blade raise! I was working on a zero clearance insert. Used the saw to make a few cuts, lowered the blade then came back to see if I had a fit and blade would not move! *SCREAMS PLEASE HELP!
UPDATE**
Ok took blade out and cleaned everything, the little worm gear that makes the sleds go up and down did have sawdust stuck in grooves so I cleaned out really well along with the rest of saw. Put it all back together and the blade raises now BUT…starting from the lowest point moving up it is VERY VERY hard to turn and to get blade to raise. About mid point it gets easier. WHY WHY WHY???
PLEASE HELP
-- TAMMYE ~ ENJOY THE DAY THE LORD HAS GIVEN US!
0 replies so far
