12'' jointer?
Forum topic by Beginningwoodworker posted 07-24-2010 04:37 PM 1931 views 0 times favorited 22 replies Add to Favorites Watch
Beginningwoodworker
13345 posts in 3702 days
07-24-2010 04:37 PM
Topic tags/keywords: jointer
Since bought the Red Oak for my mom morris chairs, most of the lumber is over 8’’ and a few peices is close to 12’’ wide. I see now why so many woodworkers like a bigger jointer, I only have a Ryobi 6-1/8 benchtop jointer and I wish I had a 12’’ jointer I cant complanit because is given to me. What do you guys think about bigger jointers?
22 replies so far
View lew's profile
lew
12102 posts in 3784 days
#1 posted 07-24-2010 04:44 PM
CJ,
Mine is a 6”. Sometimes I wish it was larger but I really don’t have the room- or the electrical requirements- for anything any larger.
Lew
117128 posts in 3606 days
#2 posted 07-24-2010 04:46 PM
I have a 12” spiral head jointer it does make things easier.
Beginningwoodworker
#3 posted 07-24-2010 04:51 PM
I really dont have the room or electrical requirements nethier. If I was still going to school I could use their 12’’ Northfield jointer.
View PurpLev's profile
PurpLev
8536 posts in 3677 days
#4 posted 07-24-2010 04:52 PM
the question is not how wide your lumber is – but how big your milled parts needs to be.
If all the parts in your morris chair are under 6” wide, then you don’t ‘NEED’ a wider jointer. more than that – if you are trying to mill your parts as wide as possible just because your rough lumber is – it means that you’ll be wasting a lot more material then if you milled your parts to their respected needed sizes. a cup in a 8” wide board will take more passes to clear out than if you’d rip (bandsaw) that part down to a smaller size and flattened it.
unless you are doing large table tops made of really wide boards, 8” may be all you’ll ever need. so far – I’m doing quite well with my 6” jointer. if I ever need something wider, I rough plane one face using hand planes, and run it through my planer to complete the milling process foregoing the jointer all together.
Now – jointer bed length – THATS a huge deal. the table top jointers with the short small bed can’t really handle longer boards well, but a jointer with a long bed makes that process so much easier and safer as you get full support for your long boards.
View miles125's profile
miles125
2180 posts in 4034 days
#5 posted 07-24-2010 04:52 PM
I have a 16”. Anything less than 12” is like assuming all boards come straight AND flat. And we all know better.
-- "The way to make a small fortune in woodworking- start with a large one"
Beginningwoodworker
#6 posted 07-24-2010 04:54 PM
I usually cut my boards down to rough lenghts before I run them though my jointer.
13609 posts in 3370 days
#7 posted 07-24-2010 05:06 PM
if you need a 12” jointer ,
you better make a bigger shop first .
they will need room on both ends .
View Roz's profile
Roz
1699 posts in 3815 days
#8 posted 07-24-2010 05:12 PM
I have an 8 inch and am very happy with it. It does all I need to do. What I wish for is a 20 inch planer.
Charles if you find your equipment is not big enough perhaps you can find a cabinet shop locally that can make the cuts you need for you or let you use thier machines.
-- Terry Roswell, L.A. (Lower Alabama) "Life is what happens to you when you are making other plans."
View vicrider's profile
vicrider
179 posts in 2927 days
#9 posted 07-24-2010 05:39 PM
I agree with Purplev,
I only have a 6” joiner. When I run into wider boards that need planing, I straighten one side with a hand plane prior to running it thru the planer. IMO, 90% of your work will be in narrower stock.
BTW, CJ, your work is progressing nicely. Keep going for the challenging stuff. I have found chairs to be one of the most difficult projects. I admire anyone who can build one.
vicrider
-- vicrider
View matt garcia's profile
matt garcia
1897 posts in 3701 days
#10 posted 07-24-2010 06:04 PM
I have an 8” jointer, but I wish I had a 16”!!!!!!
-- Matt Garcia Wannabe Period Furniture Maker, Houston TX
Beginningwoodworker
#11 posted 07-24-2010 06:10 PM
Thanks for the comments guys, you were very helpful.
View Kent Shepherd's profile
Kent Shepherd
2718 posts in 3315 days
#12 posted 07-24-2010 06:39 PM
I own a 16” jointer—It’s been unplugged for a couple of years now. Obviously I desperately need it!
It is fantastic when you need it, but is really overkill when you think about the expense and the floor space.
I happened to buy mine at an auction for a great price. I would have never considered it new.
I ran my commercial shop for years with only 6” jointers, but it definitely depends what o
you are doing.
-- http://shepherdtoolandsupply.com/
View mcase's profile
mcase
446 posts in 3158 days
#13 posted 07-24-2010 07:24 PM
I went from a 6” to an 8” with a long (43”) infeed table. I almost went for a 12” combo, but the tables are too short (lets not argue, I believe length matters, Ha, Ha, that a joke son!) There are many projects that the long beds are great for and there are days I need four more inches in width. So the truth is that if I could fit a 12” with a 42” in feed table in my shop I would. But I can’t so I opted for length. By the way, I bought the Grizzly G0490 8” and like so many others on this site I found it to be a great machine.
View jack1's profile
jack1
2107 posts in 4056 days
#14 posted 07-24-2010 11:37 PM
PurLev gives good advice. Remember woodworking tools are a lot like race cars, the faster (bigger) you want to go, the more it’s going to cost you…
View Chris 's profile
Chris
1879 posts in 4020 days
#15 posted 07-24-2010 11:47 PM
I only just got a power jointer; until now it’s just been me and my planes…..I am very happy with my 6” powermatic. The only time I think I’ll have issues is when I process wide boards for table top glue up’s. When that happens I’ll revert to my old way of doing things.
-- "Everything that is great and inspiring is created by the individual who labors in freedom" -- Albert Einstein
