question about saws
Forum topic by Jim posted 07-24-2010 02:11 PM 1307 views 0 times favorited 10 replies Add to Favorites Watch
View Jim's profile
Jim
32 posts in 2786 days
07-24-2010 02:11 PM
Topic tags/keywords: question tablesaw rustic modern
Greetings.
I’m a rookie woodworker and I want to be able to cut a small diamiter ( up to 6 inch) log down the middle. My table saw only allows me to cut up to 3.5 inches. What type of saw would work best?
Thanks, Jim
-- All who wander are not lost.
10 replies so far
View Moron's profile
Moron
5032 posts in 3796 days
#1 posted 07-24-2010 02:13 PM
cut one side, flip it, cut the other side
View TheDane's profile
TheDane
5365 posts in 3566 days
#2 posted 07-24-2010 02:20 PM
I would use a band saw. Cutting a round object like a log on a table saw would be awkward and unsafe.
View Rob Drown's profile
Rob Drown
785 posts in 3736 days
#3 posted 07-24-2010 02:27 PM
I also would prefer to use a bandsaw. I think I would screw the small log to a piece of plywood so it would not roll.
-- The expectations of life depend upon diligence; the mechanic that would perfect his work must first sharpen his tools. Confucius, 经过艰苦的努力的梦想可以成真
View richgreer's profile
richgreer
4541 posts in 2977 days
#4 posted 07-24-2010 02:45 PM
Without question, a bandsaw is the best option.
However, if you do not have a bandsaw, you could cut it on a table saw by cutting one side and flipping. I would recommend building a jig/sled to secure the log and I would recommend that you not try to cut 3+ inches in a single pass. Cut an inch or so and then raise the blade higher and cut some more. Don’t take more than an 1.5 inches in a single pass.
View BertFlores58's profile (online now)
BertFlores58
1686 posts in 2825 days
#5 posted 07-24-2010 03:05 PM
Unless you have made the log in a rectangular or square shape, don’t cut it on the table saw. You need the fence likewise the flat surface of the table.
The first question that you should have raised… how to create a flat surface on a log….
USE A PORTABLE PLANE or JOINTER.
USE A CHAINSAW.
USE AN AXE – HEWNING.
USE A ROUTER set up as a planing devise.
IF YOU MANAGE TO FLATTEN ONE SIDE, then you can cut the mid section as you have raised.
CAREFUL ON THIS … it easily kick.
-- Bert
View miles125's profile
miles125
2180 posts in 3908 days
#6 posted 07-24-2010 03:14 PM
Just screw attach a 6” wide board to the log to ride against your table saw fence (making sure screws dont hit sawblade). Then start out with blade 1” high and raise in 1” increments per pass till piece is ripped.
-- "The way to make a small fortune in woodworking- start with a large one"
View Jim's profile
Jim
#7 posted 07-24-2010 06:51 PM
Thanks guys!
View Eagle1's profile
Eagle1
2066 posts in 2967 days
#8 posted 07-25-2010 12:23 PM
I have to agree with Rich. Cutting a log or even a regular board on a ts can be dangeropus if you aren’t careful. But not a log there are jigs that you can build for the BS. Which I’m getting ready to build so I can do that same thing. Since I got the 17” BS the other day.
-- Tim, Missouri ....Inside every older person is a younger person wondering what the heck happened
View knotscott's profile
knotscott
7871 posts in 3278 days
#9 posted 07-25-2010 04:50 PM
Something like this might work, but I’d do it on a BS if I had a choice.
View SkyPaint's profile
SkyPaint
6 posts in 2763 days
#10 posted 07-27-2010 10:26 PM
Greetings. I’ve recently had to cut a log using the tools I had on hand.
I have a home made table saw. I took the log and removed as of the bark I could to smooth the log somewhat. Looking at the log I chose the a relatively smooth side with an opposite side to match and I screwed a small board to one of the smooth sides to guide the log along the fence. I could only cut about a third of the way through so I flipped the log over and made another cut on the opposite side and then cut the center using a hand saw.
Once the log was cut in half it was easy to cut out a few boards as the log has a flat edge to go by.
