| Forum topic by TopamaxSurvivor | posted 1028 days ago | 2415 views | 0 times favorited | 20 replies | ![]() |
1028 days ago |
Topic tags/keywords: scroll saw tension blade Is the scroll saw blade tensioner supposed to be released every time you stop using it or just to change the blade? -- "some old things are lovely, warm still with life ... of the forgotten men who made them." - D.H. Lawrence Wake Up America!! Please read; http://www.commondreams.org/view/2009/01/26-0 |
20 replies so far
#1 posted 1028 days ago |
PS, went on line to get the owner’s manual and the Delta site said it was unavailable at this time. -- "some old things are lovely, warm still with life ... of the forgotten men who made them." - D.H. Lawrence Wake Up America!! Please read; http://www.commondreams.org/view/2009/01/26-0 |
#2 posted 1028 days ago |
Nothing my manual about it. On handsaws it is done mainly to protect the tires on the wheel. -- Folly ever comes cloaked in opportunity! |
#3 posted 1028 days ago |
They recomend that when it is not in use that it should be released, to release the pressure off the blade. Having said that mine tends to stay on more times than not . -- Theresa, https://sites.google.com/site/tmj65treasure/ |
#4 posted 1028 days ago |
Like just about everyone else, I just leave mine tensioned. If I don’t, I know I will forget and turn it on when it isn’t tensioned. I do release the tension anyway though when I have smaller (weaker) blades like a #2 or #3 installed. -- Mike, American in Norway |
#5 posted 1028 days ago |
The reason we release the tension on a bandsaw is to take the pressure off the tires. Furthermore, the tension on a bandsaw blade is much higher than the tension on a scroll saw blade. I see no reason to release the tension and I see no harm if you do (other than forgetting to reapply the tension before you start the next time). -- Rich, Cedar Rapids, IA - I'm a woodworker. I don't create beauty, I reveal it. |
#6 posted 1028 days ago |
What is the model number of your Delta scroll saw? Maybe someone has that model and could copy the manual for you. -- John at Sugarloft Mountain........Don't argue with an idiot; people watching may not be able to tell the difference. |
#7 posted 1028 days ago |
It is a Delta 40-540. Mike, that is what happened to me the other day; i started without tightening. Being a novice with the scroller, I wondered why it cut so poorly:-)) I finally noticed the blade seemed a bit too wobbly :-)) :-)) Cut a lot better after that!! I tend to forget to release and to tighten. I have a new appreciation for scrollers ability. Cutting those perfect radii time after time is a real talent! Looks to me like it is nearly impossible to take those intricate designs to the belt sander to clean up the lines:-) -- "some old things are lovely, warm still with life ... of the forgotten men who made them." - D.H. Lawrence Wake Up America!! Please read; http://www.commondreams.org/view/2009/01/26-0 |
#8 posted 1028 days ago |
Most of the time I either take the blade out or leave it tensioned. If the is no blade in the machine no one can use it or accidentally turn it on and get cut. I worry about that. I checked my manual (hitachi) and it didn’t say anything about leaving blades tensioned. -- ----- www.KNWoodworking.com ----- -- |
#9 posted 1027 days ago |
I have to agree with Rich. I release the tension on my BS but not on my scrollsaw, it’s straight no tires to flatten out,The BS is always changing it’s shap in a way, because it is turning, which in my mind it is bending more than a straight blade and kust moving up and down. It does move from side to side. But I don’t think it does as much as a BS does. -- Tim, Missouri ....Inside every older person is a younger person wondering what the heck happened |
#10 posted 1026 days ago |
Thanks for the info everyone. Guess I won’t worry about it:-)) -- "some old things are lovely, warm still with life ... of the forgotten men who made them." - D.H. Lawrence Wake Up America!! Please read; http://www.commondreams.org/view/2009/01/26-0 |
#11 posted 1026 days ago |
Topamax and others I have seen a blade that was tensioned a ½year and you cuoldn´t use the saw just my 2cent Dennis |
#12 posted 1026 days ago |
Thanks Dennis, maybe i should rethink my previous comment ;-) It is probably good practice to release anything under tension when not in use. -- "some old things are lovely, warm still with life ... of the forgotten men who made them." - D.H. Lawrence Wake Up America!! Please read; http://www.commondreams.org/view/2009/01/26-0 |
#13 posted 1026 days ago |
Topa don´t bee tooo quick or put a stone under the wheel |
#14 posted 1026 days ago |
“P-brake”???? What’s a P-brake? -- "some old things are lovely, warm still with life ... of the forgotten men who made them." - D.H. Lawrence Wake Up America!! Please read; http://www.commondreams.org/view/2009/01/26-0 |
#15 posted 1026 days ago |
I have quite literally left the blade tensioned on this particular model for years with NO ill effects. Besides, blades are so cheap that you really should put a new one in at the beginning of each new project anyway. IMO, don’t over think this, it is a non-issue. Hail, I didn’t even remove the rust off the SS table for the first +15 years, just WD-40’d it once in a while. Still runs like a champ. There is probably more danger to NOT having the blade tightened than leaving it tightened. Anyway, dug up all the old paperwork on mine and made a copy of the safety chart for you. I even found my receipt stapled to the Warranty envelope, dated 03/07/93. FYI, in 1993 it cost me $179.00 USD. -- HorizontalMike -- "Woodpeckers understand..." |
| Forum | Topics |
Woodworking Skill Share
8781 |
Woodturning
219 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
77 |
Finishing
1521 |
3541 |
15746 |
Hand Tools
2027 |
Jigs & Fixtures
493 |
Wood & Lumber
2832 |
808 |
Focus on the Workspace
899 |
766 |
Woodworking Trade & Swap
2736 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6148 |
