Question about joining plywood edge to edge
« back to Joinery forum
Forum topic by georgeet posted 11-20-2016 10:31 PM 489 views 0 times favorited 3 replies Add to Favorites Watch
View georgeet's profile
3 posts in 1454 days
11-20-2016 10:31 PM
Topic tags/keywords: plywood butt joint dowel joint router joint joining
I’m an artist and am working on some shaped canvases using plywood forms for the stretchers. I want to avoid wastage and cut out the forms in parts rather than use up a single sheet. I made one so far cut in two long pieces and joined using dowels with a butt joint, but I’m wondering if I could make that stronger. I rout the adjoining edges so they match so I could easily (I think) cut a short scarf joint with an angle bit or even cut some sort of finger or puzzle joint along with the dowels. There will be a steel strap on one side to keep it straight.
Do I need to bother making the joint more complicated or is a doweled butt joint fine? Any advice?
This is an example of what I’m doing (ignore the branch). This was cut from 3/4” plywood in two long pieces app. 48” lomg and joined on the short sides. Thanks for any help.
3 replies so far
View cabmaker's profile
1706 posts in 2742 days
#1 posted 11-20-2016 11:06 PM
if one side is not to be exposed to the view corrugated fasteners would be perfect !
View Loren's profile
10096 posts in 3581 days
#2 posted 11-20-2016 11:07 PM
Dowels are fine.
View corelz125's profile
361 posts in 909 days
#3 posted 11-20-2016 11:55 PM
Also use pocket hole screws
