Barrel Hinges
Forum topic by davidtheboxmaker posted 318 days ago 181 views 0 times favorited 2 replies Add to Favorites
View davidtheboxmaker's profile
davidtheboxmaker
353 posts in 334 days
318 days ago
Topic tags/keywords: question drill press modern
My main interest is making small boxes.
I’ve tried to use barrel hinges but am struggling to get the hole dimensions correct.
Does anyone have any expertise on this?
View roman's profile
roman
474 posts in 422 days
318 days ago
There are so many kinds of barrel hinges out there.
I assume yours are the hidden kind where each side of the barrel is drilled into the corrosponding box part.
A horizontal boring machine is nice but few can afford such luxuries. I make a jig and use a drill press.
Again, the hole dia., would depend upon the hinge. A set of calipers would give you the right dia to drill.
regardless of the hinge they are a PITA to install. A trial and error method works for me.
Good Luck
davidtheboxmaker
317 days ago
Your description matches the type of hinge I’ve tried.
Its setting the depth that is proving difficult for me.
Bookmark And Share This Page
