New Woodworker Question: Bandsaw cut quality
Forum topic by PocketHole69 posted 07-23-2010 04:51 PM 3746 views 0 times favorited 5 replies Add to Favorites Watch
View PocketHole69's profile
PocketHole69
79 posts in 3278 days
07-23-2010 04:51 PM
Topic tags/keywords: bandsaw adjustment
Hey, I just got my first bandsaw yesterday, a Jet 10” model, and spent an hour or so adjusting the guides and table per the manual. I made a few test cuts on scraps that I had laying around the garage, but I noticed that the cut is not very smooth compared to say, my table saw. It cuts straight and without problems, but the cut is “rough” with 1/32” teeth marks down the length of the cut. It’s not bad- a simple sanding on my drill press sanding drum will remove them, but its definitely not smooth.
Complete newbie question: Is this normal?
I’ve never owned a bandsaw before, so I have no idea what a “good” cut should look like from one. Do I need to do some more adjustment, or buy a better blade, or is this just how bandsaws cut?
-- Jason, Atlanta, GA
5 replies so far
View NBeener's profile
NBeener
4816 posts in 3415 days
#1 posted 07-23-2010 04:55 PM
Sure sounds like a blade (and/or feed rate) issue.
May want to take a quick course in bandsaw blades:
http://www.supercutbandsaw.com/how_to_choose.html
Good luck !
-- -- Neil
117420 posts in 3818 days
#2 posted 07-23-2010 04:59 PM
Hey Jason
It’s probably your blade oddly enough band saw blades with fewer teeth cut better ,try a blade with 3 teeth per inch.
PocketHole69
#3 posted 07-23-2010 05:04 PM
Ok, after using google image search looking for pieces of wood cut with a bandsaw my results look almost exactly like the image below:
Bandsaw cut
So I guess I have it tuned correctly? I just need a baseline image to know what a “good” bandsaw cut looks like so I know where to go from here.
PocketHole69
#4 posted 07-23-2010 05:05 PM
Neil and Jim- Yeah, I am using the stock blade that came with the saw. I’ll have to upgrade it in the near future once my wife forgets how much I spent on the saw :)
View PurpLev's profile
PurpLev
8548 posts in 3889 days
#5 posted 07-23-2010 05:21 PM
it’s called ‘stock blade syndrome’ – very common on all bandsaws.
give your bandsaw 1 tylanol every 4 hours, and a new quality blade, and it should clear out real well, real quick.
