wet sanding colored danish oil
Forum topic by Scott C. posted 11-18-2016 08:10 PM 846 views 0 times favorited 3 replies Add to Favorites Watch
View Scott C.'s profile
Scott C.
160 posts in 2199 days
11-18-2016 08:10 PM
I’ve had success in the past wet sanding natural danish oil into oak for the purpose of grain filling, anyone done this with the colored versions? I’m specifically looking at the red mahogany danish oil wet sanded into white oak. I really dislike how the open pores of oak get so dark when stained, practically black. I’m hoping wet sanding the colored danish oil will achieve a more uniform coloring and grain fill at the same time.
-- measure twice, cut once, swear and start over.
3 replies so far
View bilyo's profile
bilyo
347 posts in 1251 days
#1 posted 11-19-2016 02:33 AM
I don’t think that the color of the oil will make much difference to the color of the pores. If anything, it will make them darker. I’m not sure what the answer is unless you use a light colored grain filler first. I’ve used one of the clear fillers and was not impressed. Maybe it’s my technique. From the perspective of trying to get the pores lighter, the clear filler doesn’t work because you need to put on your stain first. Might be OK if you are not using a stain; just keeping it its natural color. Another way to do it might be to seal the wood first with shellac or finish and then use a colored glaze. I have successfully used a gel stain over sealer, but it doesn’t end up as dark. It works a little better to apply shellac or finish to the bare wood, sand it back just enough to leave finish in the pores, and then apply stain.
View bigJohninvegas's profile
bigJohninvegas
490 posts in 1610 days
#2 posted 11-19-2016 02:50 AM
Try it on a scrap piece and see what happens. Never know what you may get.
-- John
View OSU55's profile
OSU55
1869 posts in 2138 days
#3 posted 11-20-2016 02:19 PM
Try dye instead of box store pigmented stains. You need to use oil based, water/alcohol based dyes don’t color the pores due to surface tension and the tannic acid. I use WD Lockwood. Here's something that may help.
