cut a 48 degree angle
Forum topic by robc posted 07-23-2010 12:22 PM 3180 views 0 times favorited 4 replies Add to Favorites Watch
View robc's profile
robc
22 posts in 3285 days
07-23-2010 12:22 PM
Topic tags/keywords: corner cabinet window seat angle how 48 degree tip question resource
I am building a strange corner cabinet for a window seat.
The base is 21 11/16 across the front, 4.5 inch deep on the left and 24 on the right. Both the left and right side have to be cut at an angle so the back with fit on, 1/2 back screwed and glued. How do you cut a 48-degree angle on the vertical side of cab walls? Hope this makes sense to someone.
View Gene Howe's profile
Gene Howe
11167 posts in 3669 days
#1 posted 07-23-2010 01:05 PM
Could’nt you set your TS blade to the proper angle and rip the sides?
View antmjr's profile
antmjr
262 posts in 3424 days
#2 posted 07-23-2010 01:21 PM
Gene, I guess he can only set his blade to 45-46 degree at most
If I understand it correctly, I’d fix a thin plank on the table, parallel to the blade, 50-60 cm apart.
Then I’d cut a piece of scrap panel. This panel lies on the table near the blade, and on the plank on the other side; therefore the cut will have an angle, say 10,23° or 8,7548°, I mean it’s not important. You have to measure it and to subtract it from 48°. Then set the blade to this difference and cut your panel, it will have 48 degree obviously.
-- Antonio
View BertFlores58's profile
BertFlores58
1698 posts in 3163 days
#3 posted 07-23-2010 04:02 PM
In this case, I use to old style my father told me….. Cut 45 degrees on both and and clamped them together to form 90. Obviously a 6 degree offset will be present… Just saw it in the middle to make a perfect fit. this may take two times sawing depending on the kerf of the saw to cut the 6 degree offset. This is exactly the technique used for exact fitting of miterred frames where you saw those corners to have a perfect fit.
-- Bert
View tbone's profile
tbone
276 posts in 3925 days
#4 posted 07-23-2010 06:26 PM
If I understand correctly, you could use a router and a straight edge clamped on the material at 48°.
Or, when in doubt, get out the hand plane.
-- Kinky Friedman: "The first thing I'll do if I'm elected is demand a recount."
