Moisture Meters
Forum topic by kzot posted 07-23-2010 12:22 AM 3803 views 0 times favorited 6 replies Add to Favorites Watch
View kzot's profile
kzot
10 posts in 3089 days
07-23-2010 12:22 AM
Topic tags/keywords: moisture meter moisture content wood moisture question
Any suggestions on the ‘favored’ moisture meter? Which is better, pin type or digital?
-- Kzot
View Sawmillnc's profile
Sawmillnc
150 posts in 2958 days
#1 posted 07-23-2010 03:15 AM
I use Lignomat..pinned with the extensions for thicker stock.
-- Kyle Edwards, http://www.sawmillnc.com, Iron Station , NC (near Charlotte)
View mvflaim's profile
mvflaim
189 posts in 2995 days
#2 posted 07-23-2010 04:23 AM
I never used Lignomat or any other high end moisture meters but the one I own is a Ryobi that I bought at Home Depot for $60 and it does a good job. It’s pinless and gives an accurate enough measurement of moisture in the wood.
16272 posts in 4122 days
#3 posted 07-23-2010 04:29 PM
I have the same Ryobi pinless that mvflaim has. It seems to work well, although I have no way of knowing how accurate it really is.
View kzot's profile
kzot
#4 posted 07-23-2010 05:36 PM
Thanks for all of your responses. I asked for ‘favored’ moisture meter and you delivered.
-- Kzot
View Greedo's profile
Greedo
473 posts in 2864 days
#5 posted 07-23-2010 06:00 PM
you can check the accuracy of digital meters by testing them on your skin. from memory it should read about 8%, but im not sure anymore.
but then even with a meter, you can only see the real moisture value when you cut open the piece of wood and measure at the center. measuring on the end of boards or the outside edge will give a lower value than is real.
i bought one to check the humidity of wood at the lumberyard before buying, but it’s pointless unless they let you cut their wood in half to check.
View pvwoodcrafts's profile
pvwoodcrafts
243 posts in 3825 days
#6 posted 07-23-2010 10:03 PM
I like my 609 wagner pinless
-- mike & judy western md. www. pvwoodcrafts.com pvwccf1@verizon.net
