Hand Plane Trouble
Forum topic by jimmymmc posted 11-17-2016 08:45 PM 667 views 0 times favorited 9 replies Add to Favorites Watch
View jimmymmc's profile
jimmymmc
1 post in 795 days
11-17-2016 08:45 PM
I recently bought a low angle jack plane and a number 4 smoothing plane.
I seem to be on the right track with the jack plane, but I experience a lot of tear out with the smoothing plane and I am not getting the same thin continuous ribbon that I see people get on youtube videos.
I try adjusting the depth of the iron, but it’s either to shallow and doesn’t touch the wood, or it’s too deep and gougues to deep into the wood.
Should I be waxing the plane base?
Sharpen the blade? I’ve been using the blade right out of the box, but figure its still pretty sharp.
9 replies so far
View HerbC's profile
HerbC
1792 posts in 3098 days
#1 posted 11-17-2016 09:29 PM
Sharpen the blade!
-- Herb, Florida - Here's why I close most messages with "Be Careful!" http://lumberjocks.com/HerbC/blog/17090
View mike02130's profile
mike02130
170 posts in 912 days
#2 posted 11-17-2016 09:35 PM
Like he said, sharpen blade first ask questions later. Process of elimination. Just like trouble shooting a four stroke motor. Check for fuel and spark. Proceed from there.
-- Google first, search forums second, ask questions later.
View Marn64's profile
Marn64
296 posts in 1025 days
#3 posted 11-17-2016 10:51 PM
I third the sharpening advice :)
-- Benjamin, Milwaukee
View JayT's profile
JayT
6009 posts in 2450 days
#4 posted 11-17-2016 10:55 PM
Did someone mention sharpening the iron? ;-) I’ve not seen a plane yet that comes out of the box really ready to use. Even the high end ones need honing before touching wood.
And yes, waxing the sole of the plane will help.
-- In theory, there is no difference between theory and practice. In practice, there is.
View bondogaposis's profile
bondogaposis
5151 posts in 2590 days
#5 posted 11-18-2016 12:19 AM
Nope, out of the box = dull. Flatten the back then sharpen. New planes are not sharp.
-- Bondo Gaposis
View HokieKen's profile
HokieKen
7584 posts in 1378 days
#6 posted 11-18-2016 02:35 AM
Did you sharpen the la jack? I’m surprised it’s not giving you a fit if you didn’t
Definitely flatten the back and make sure the chip breaker is set properly. Those 2 things are particularly important with a smoother but should be done on all planes.
-- Kenny, SW VA, Go Hokies!!!
View kryptix's profile
kryptix
100 posts in 830 days
#7 posted 11-18-2016 08:00 PM
Well I did recently get a LA Jack from Lie Nielsen and that came out of the box sharp enough to get fine continuous shavings on pine and cedar… Not quite the same thing as fine continuous shavings on figured maple though, and they even recommend putting on a micro bevel before serious use.
View johneone's profile
johneone
11 posts in 4290 days
#8 posted 11-19-2016 03:50 AM
I don’t know, but I think you should sharpen the blade :)
-- John from Murrieta
mike02130
#9 posted 11-20-2016 12:21 AM
Did you sharpen the blade yet?
