Starting new with sawhorses.
Forum topic by Garret D., Rock Run posted 11-17-2016 06:35 PM 1159 views 0 times favorited 18 replies Add to Favorites Watch
View Garret D., Rock Run's profile
Garret D., Rock Run
72 posts in 1852 days
11-17-2016 06:35 PM
So now that I have the wood shop I need to start on the project list, the first item that I’m going to start with it’s going to be a new set of saw horses. Saw horses always seem like a great starting point when your at a woodworking plateau.
When I’m making a new set of saw horses I like to compare them to the saw horses of the past and see the changes in ideas, techniques and skill level. For me the sawhorse represents the baseline of my woodworking.
The brilliant thing about sawhorse as as there’s really as many different sawhorse designs as there are Woodworkers. So come on guys what do your saw horses look like?
18 replies so far
Smitty_Cabinetshop
15380 posts in 2674 days
#1 posted 11-17-2016 06:38 PM
I’d call this C. Schwarz’ 1st Generation sawbench.
It’s the same height height as my toolchest, but is a separate thing entirely from the (many) pairs of sawhorses that are scattered around the shop.
Garret D., Rock Run
#2 posted 11-17-2016 07:00 PM
I d call this C. Schwarz 1st …
Brilliant. Do you have a pic of the tool chest?
View Douglas's profile
Douglas
424 posts in 2616 days
#3 posted 11-17-2016 07:20 PM
I made a C Schwarz style saw bench, and I hate it. It looks cool, and is great as a bench, but I hate the splayed legs. Those legs seem to interfere with sawing all the time. I’m going to replace it with a bench that has straight vertical legs, and maybe a split top.
-- Douglas in Chicago - https://dcwwoodworks.com
View bondogaposis's profile (online now)
bondogaposis
4840 posts in 2407 days
#4 posted 11-17-2016 08:40 PM
I like these I built them a few years ago and they have held up really well. You can make the pair from 5 2×4’s about $10 just about anywhere. Cheap and sturdy, what is not to like?
-- Bondo Gaposis
View MrRon's profile
MrRon
4869 posts in 3299 days
#5 posted 11-17-2016 09:27 PM
here is the sawhorse I use. It has a wide top for more stability. They are lightweight, but very strong. https://s3.amazonaws.com/vs-lumberjocks.com/ogt29kg.jpg!
View DMC1903's profile
DMC1903
285 posts in 2383 days
#6 posted 11-17-2016 09:38 PM
I opted to purchase a couple of Dewalt collapsible sawhorse’s, they are lightweight and store easily and a nice height.
View mike02130's profile
mike02130
167 posts in 729 days
#7 posted 11-17-2016 09:40 PM
Mine are buried and not photo available. I have a few pairs of carpenter type horses. I made one longer and wider than the other so they can stack together.
-- Google first, search forums second, ask questions later.
Garret D., Rock Run
#8 posted 11-17-2016 09:46 PM
View Jim Jakosh's profile
Jim Jakosh
20781 posts in 3161 days
#9 posted 11-17-2016 10:14 PM
hi Garret,
Mine are buried too, but they have steel brackets that I made that you bolt 4 2×4 legs to and then one 30” 2×4 on edge across the top. They are fixed and don’t fold but they stack on top of each other pretty good and that is where they are now- stacked in the outback shed!!
Cheers,.......................Jim
Garret D., Rock Run
#10 posted 11-18-2016 12:23 AM
hi Garret,
Mine are buried too, but they have steel brackets that I made that you bolt 4 2×4 legs to and then one 30” ...
- Jim Jakosh
Mathias Wandel did a deconstruction video of something like that model of sawhorse. I seem to remember him being favorably impressed.
Smitty_Cabinetshop
#11 posted 11-18-2016 12:58 AM
Garret, you’ll find a couple hundred pics of the chest in it’s various forms in the project post and blog series here on LJs…
View BobAnderton's profile
BobAnderton
270 posts in 2846 days
#12 posted 11-18-2016 01:20 AM
So, these aren’t pretty anymore, but I like this design a lot. I made these about 30 years ago. The main beam is an I beam construction, and I like how the legs tuck in under the top of the beam so they are in pure compression. As a result, the connection between the legs and the main beam isn’t really in shear stress. They are as strong as heck and easy to make. The little vertical pieces to hold logs on top were added later.
-- Bob Anderton - Austin, TX - Nova 3000 lathe, Alaskan Mark III mill, Husqavarna Saw
Garret D., Rock Run
#13 posted 11-18-2016 01:55 AM
So, these aren t pretty anymore, but I like this design a lot. I made these about 30 years ago. ...
- BobAnderton
Oh nice. So you are using the Alaskan Mill up on that. That is a pretty sweet setup.
Garret D., Rock Run
#14 posted 11-18-2016 01:57 AM
Garret, you ll find a couple hundred pics of the chest in it s various forms in the project post and blog series here on LJs…
- Smitty_Cabinetshop
That’s one great piece of shop infrastructure there. Pretty awesome.
View Ron Aylor's profile
Ron Aylor
2649 posts in 703 days
#15 posted 11-19-2016 12:22 AM
I use a not-so-fancy split top saw bench. This is great for ripping! Made mine 19-1/4” high …
... to line up with the wooden casket stands salvaged from the funeral home!
Sorry it’s so dark back there …
