What Happened to Ridgid LSA ?
Forum topic by HorizontalMike posted 11-16-2016 05:47 PM 1620 views 0 times favorited 57 replies Add to Favorites Watch
View HorizontalMike's profile
HorizontalMike
7758 posts in 2937 days
11-16-2016 05:47 PM
Topic tags/keywords: ridgid lsa lifetime service agreement planer lunchbox
Well my Ridgid R4330 lunchbox planer smoked on me this morning, so I came inside to “find” the nearest Ridgid service center in my area. NOT GOOD.
The “nearest” authorized service center is 142mi. away. And the second closest is 171mi. from home! WTF?
WHAT HAPPENED TO RIDGID?
Are they about to go belly up?
I checked a few years ago and there was a service center within 40mi. in San Antonio… Geez… this sure changes my “TOOL” perspective… 8-(
57 replies so far
View Joe Lyddon's profile
Joe Lyddon
10117 posts in 4075 days
#1 posted 11-16-2016 06:44 PM
Maybe they want you to Ship it to them?
... does NOT sound very good…
Good Luck!
TopamaxSurvivor
18285 posts in 3699 days
#2 posted 11-16-2016 06:51 PM
The guy here in Tacoma told me years ago his compensation rates were so low, he actually made his living doing the pickup and delivery. I just checked and he is gone, but there are 2 larger companies now listed as service centers in the area. No idea what to think. Home Depot owns Ridgid.
View JoeinGa's profile
JoeinGa
7736 posts in 2030 days
#3 posted 11-16-2016 06:54 PM
You “SHOULD” be able to take it to ANY HD store. Some stores with Tool Rental depts. are designated repair stores and the ones that are not can send it to the Service Center for you.
HorizontalMike
#4 posted 11-16-2016 07:24 PM
I have no idea Joe. My thoughts are that I could chew up ~$200 shipping both ways OR ~$100 on gas for two round trips (plus wasting 2-days of my time). Kind of a lose lose situation.
This particular planer is STILL just $369. at the big box store. I think I paid that much over 6yr ago. BTW, I also have two sets of new blades for this machine as well ($60).
Anyway, it was smoking at the on/off switch yet failed to activate the reset breaker. I was in the process planing a handful of pieces of Claro Walnut and had to plane ever-so-lightly in order to prevent tearout. That meant that I had the machine running constantly for maybe 30min. but don’t know for sure. The machine wiring must have melted and it began shutting down. I hit the OFF before the reset even had time to trip. Waited for long cool down, blew out the switch area with compressed air, etc. It still will not start. Took the dust shroud off and looked inside and saw what appeared to be a green ground wire with discolored insulation.
Don’t know if it is worth even trying to fix it. Don’t know if the “new” same model would be worth thinking about, especially with the LSA being worthless and all. Still wondering if RIDGID is a sinking ship or not…
Not very interested in up-sizing since I don’t know if I’ll get enough use out of it…
HorizontalMike
#5 posted 11-16-2016 07:32 PM
- TopamaxSurvivor
Financially, HD is beating the pants of of Lowes recently. Not sure what that means for RIDGID though. And the compensation rates is probably why so fe3w service centers in Texas.
__
And Joe, I’ll check HD as you suggest. All I know is that the RIDGID.com sight was NOT helpful at all when it comes to getting service. I suspect that if what you say was true, that website would have should have communicated that info since HD owns them.
View waho6o9's profile
waho6o9
8207 posts in 2600 days
#6 posted 11-16-2016 07:56 PM
Dewalt planers would be better IMHO
http://sanantonio.craigslist.org/search/sss?query=+planer&sort=rel
Good luck now
View MrUnix's profile
MrUnix
6764 posts in 2222 days
#7 posted 11-16-2016 08:08 PM
Anyway, it was smoking at the on/off switch yet failed to activate the reset breaker. I was in the process planing a handful of pieces of Claro Walnut and had to plane ever-so-lightly in order to prevent tearout. That meant that I had the machine running constantly for maybe 30min. but don t know for sure.
- HorizontalMike
That sounds like the machine is fine, but you had a failure of the switch. If that is the case, it’s a pretty easy fix, and equally easy to test the theory by just bypassing the switch to see if it runs. If you can determine exactly what it is that has failed, you might be able to get them to ship a replacement part – negating the need to ship or transport the thing to them. Just make sure you identify the problem, and perhaps take some pictures to verify to them you know what you are talking about. I’ve never dealt with Ridgid, but had done so with other manufacturers. I’ll usually describe the problem in detail and give them the part number needed – and it shows up in the mail a few days later. On at least one occasion, they (Delta) didn’t even bother asking for proof of purchase, warranty or anything other than an address to ship it to.
HorizontalMike
#8 posted 11-16-2016 08:10 PM
Good luck now
- waho6o9
I have thought about DeWalt, but not likely to buy used jobsite type tools/machines here in Texas. Too many temp workers buying them at box stores, using them and then returning them. Lots of that stuff going on around here.
Thanks for the idea though.
HorizontalMike
#9 posted 11-16-2016 08:16 PM
...That sounds like the machine is fine, but you had a failure of the switch. If that is the case, it s a pretty easy fix, and equally easy to test the theory by just bypassing the switch to see if it runs. If you can determine exactly what it is that has failed, you might be able to get them to ship a replacement part – negating the need to ship or transport the thing to them. Just make sure you identify the problem, and perhaps take some pictures to verify to them you know what you are talking about. Just a thought.
- MrUnix
That may very well be. Was having troubles with switch after machine set unused for extended time. Will probably tear into it in next day or so. Just too peeved at it today.
Yeah, pictures always help.
Joe Lyddon
#10 posted 11-16-2016 08:28 PM
- HorizontalMike
That sounds like the machine is fine, but you had a failure of the switch. If that is the case, it s a pretty easy fix, and equally easy to test the theory by just bypassing the switch to see if it runs. If you can determine exactly what it is that has failed, you might be able to get them to ship a replacement part – negating the need to ship or transport the thing to them. Just make sure you identify the problem, and perhaps take some pictures to verify to them you know what you are talking about. I ve never dealt with Ridgid, but had done so with other manufacturers. I ll usually describe the problem in detail and give them the part number needed – and it shows up in the mail a few days later. In at least one occasion, they didn t even bother asking for proof of purchase, warranty or anything other than an address to ship it to.
- MrUnix
I agree 100%...
Sounds like a wiring / switch failure… BUT, WHY? It doesn’t sound like the machine was in a huge STRESSFUL mode at the time. ... could affect the motor… if so, big problem…
Warranty supposed to cover this 100%?
View mike02130's profile
mike02130
167 posts in 696 days
#11 posted 11-16-2016 08:37 PM
Home depot doesn’t sell what people want to buy. They sell what they want you to buy.
-- Google first, search forums second, ask questions later.
View SignWave's profile
SignWave
440 posts in 3058 days
#12 posted 11-16-2016 09:21 PM
Don t know if it is worth even trying to fix it. Don t know if the “new” same model would be worth thinking about, especially with the LSA being worthless and all. Still wondering if RIDGID is a sinking ship or not…
- HorizontalMike
I know it’s frustrating at the moment, because I find myself in that situation from time-to-time.
It happened to me with a pressure washer last week, and I was thinking about buying a new one because parts are scarce and cost about the same cost as a new unit. Then after setting it aside for a few days, I saw that there were two bolts that had sheared in half. I extracted the broken bolts, and threw in some replacements, and finished my task. It doesn’t always work out this well, but often times our troubleshooting brain can get hijacked by the frustration.
Sounds to me like you might be able to fix this yourself. Not what Ridgid promised, but still cheaper than a new one. I hope this is the case, anyway.
-- Barry, http://BarrysWorkshop.com/
SignWave
#13 posted 11-16-2016 09:23 PM
Home depot doesn t sell what people want to buy. They sell what they want you to buy.
- mike02130
This is so true. I have lamented about not being able to find things I’m looking for there for years. A while back I got a HD gift certificate for Christmas. I needed a corded drill, but didn’t want any of the ones they had in the store (for various reasons). I was able to find one online and use the gift certificate that way.
4999 posts in 2516 days
#14 posted 11-16-2016 09:49 PM
I haven’t looked close enough at the warranty I guess. I thought any HD could take care of your problem…I’ll have to go back and read again.
TopamaxSurvivor
#15 posted 11-16-2016 10:03 PM
I agree that it is probably the switch based on your description. The switch most likely failed because they are cheap and designed to last a few thousand operations. When we could buy products made to the old National Electrical Manufacturers Association standards, they were designed to last a million operations.
showing 1 through 15 of 57 replies
