Looking for advice on resurfacing a front door.
Forum topic by thehig posted 11-16-2016 05:31 PM 568 views 0 times favorited 7 replies Add to Favorites Watch
View thehig's profile
thehig
1 post in 760 days
11-16-2016 05:31 PM
Topic tags/keywords: question
Hello All,
I am new to woodworking but I have a problem and could use some advice. My front door has been gouged up by dogs. Replacement is expensive as the door is an odd size 34” wide. Is there a planer that would be able to resurface something that wide?
Appreciate any advice or suggestions.
Thanks!
Tom
7 replies so far
View OnhillWW's profile
OnhillWW
144 posts in 1435 days
#1 posted 11-16-2016 10:04 PM
W/o pictures and assuming that this is a flat wood door that you do not want to paint: dog scratching may be lessened by steaming the affected areas and raising the grain (lightly sand area prior to steaming to expose raw wood. Cover small areas with a moist towel and heat with a hot iron, 2 or more attempts may be needed to get maximum effect, let dry. Get a hold of a 6” Random orbital sander and level affected areas the best you can trying to blend into non-affected regions of the door so that you don’t replace scratches with divots. May not be perfect but could be much better. Can’t really say w/o seeing pictures.
-- Cheap is expensive! - my Dad
View jerryminer's profile
jerryminer
944 posts in 1644 days
#2 posted 11-17-2016 02:58 AM
We need to know more about the construction of the door. I have successfully cut off 1/8” from the face of a door rail (in a frame-and-panel door) with a router and let in a new piece.
So—- slab door, frame-and panel…?? Pics?
View GR8HUNTER's profile
GR8HUNTER
5141 posts in 915 days
#3 posted 11-17-2016 04:44 PM
pictures or it DID NOT HAPPEN please
View ArtMann's profile
ArtMann
1153 posts in 1018 days
#4 posted 11-17-2016 04:54 PM
Not long ago, I helped a guy turn a section of bowling alley into a workbench top. We carried the slab to a millwork company that had a huge wide belt sander. They ran it through about 4 times and it was flat and without blemish. Maybe you can find a business like that or a cabinet shop to do the coarse surfacing for you and you can finish it up with a ROS.
View rwe2156's profile
rwe2156
3171 posts in 1683 days
#5 posted 11-17-2016 06:28 PM
Without know how deep the dings are, its hard to advise.
One option would be remove the paint or finish, bondo all the dents, sand and paint.
Or you can buy a 36” wide door are a ReStor or Thrift store and trim it down. Or you may even find a 34” door.
View Cooler's profile
Cooler
299 posts in 1046 days
#6 posted 11-17-2016 06:42 PM
- rwe2156
Another would be move the paint or finish, bondo all the dents, sand and re-skin. They sell wide veneers for doors (Lowes carries red oak and birch); some places sell “door skins” which is about 1/8” thick plywood with a veneer surface.
Exotic veneers are available: http://veneers.com/doors/
Constantines sells veneers with a self adhesive backing in exotic flavors (like genuine burl, and South American rosewood): http://www.constantines.com/peel-n-stick.aspx
I would check with ML Condon too: http://www.condonlumber.net/Plywood.html
-- This post is a hand-crafted natural product. Slight variations in spelling and grammar should not be viewed as flaws or defects, but rather as an integral characteristic of the creative process.
View Kelly's profile
Kelly
2132 posts in 3147 days
#7 posted 11-17-2016 07:16 PM
When need arises, I’m a fan of aluminum, brass or metal like we see on doors that get kicked, pushed by carts and so on. Done right, they play well with wood. Of course, they always play fine with metal or glass.
