Band Saw for a dummy?
Forum topic by chughes10 posted 11-16-2016 05:30 PM 587 views 0 times favorited 11 replies Add to Favorites Watch
View chughes10's profile
chughes10
4 posts in 613 days
11-16-2016 05:30 PM
Topic tags/keywords: band saw saw butternut question wood
I am getting into some smaller woodworking projects, so I figured I would ask some advice about what kind of band saw to purchase. I have no experience with band saws, but I am working with butternut wood in a 2×4 size, which is incredibly dense hardwood. Cutting it by hand is painful, and sloppy. I am looking to invest in a low to mid-range band saw, something that won’t run me more than a few hundred bucks. I see a lot of people saying that the lower (2.5-3.5) amp saws are terrible for cutting thicker wood. I want to be able to manipulate at least a 32 inch 2×4 board, but I am planning some more DIY projects that might require something a little bit larger. Any ideas?
11 replies so far
View mrbob's profile
mrbob
182 posts in 625 days
#1 posted 11-16-2016 05:33 PM
A used 12 or 14” Delta would do it for you, but unless your find a deal, it maybe a bit out of your price range.
View Loren's profile
10476 posts in 3704 days
#2 posted 11-16-2016 05:36 PM
i don’t really recommend any wood band saw under
12” unless it’s the old INCA 340, which is precisely
made and collectible. You can keep your eye out
for one, but a used 12” or 14” saw will be easier
to find.
View bondogaposis's profile (online now)
bondogaposis
4840 posts in 2407 days
#3 posted 11-16-2016 05:38 PM
Don’t get anything less than a 14” saw. The smaller saws have shorter blades which generates a lot more heat and they tend to break easily. A 14” saw runs cool and can handle thicker wood and is ideal for band saw boxes and such and you can re-saw larger wood with it.
-- Bondo Gaposis
View gargey's profile
gargey
1010 posts in 832 days
#4 posted 11-16-2016 05:40 PM
...but I am working with butternut wood in a 2×4 size, which is incredibly dense hardwood…- chughes10
False.
http://www.wood-database.com/butternut/
27 lbs per cubic foot.
Janka 490
It is a low density, very soft hardwood. If you’re confused by my use of the word “hardwood,” then:
Hardwood = not pine. Softwood = pine.
“Incredibly dense” would better describe, for instance, Live Oak, which is ~60 lbs per cubic foot, and ~2,500 Janka (more than twice as heavy, and five times harder).
Nothing against using power tools, but cutting butternut by hand should be quite easy if you don’t have a mountain of it to cut. Maybe you need some sawing instruction/practice.
chughes10
4 posts in 613 days
#5 posted 11-16-2016 05:42 PM
Sorry, I guess I got my facts wrong. My main point is that as far as wood goes, it is really hard to cut by hand. It may be low density, but it has wrecked several of my jig saw blades when I tried to use that to cut it. I figured it would be good to get some opinions on it. Thanks
False.
Janka 490
It is a low density, soft hardwood. If you re confused by my use of the word “hardwood,” then:
- gargey
gargey
#6 posted 11-16-2016 05:52 PM
Maybe you have to go more slowly with the jigsaw, given the 2” thickness? Maybe your jigsaw cannot handle 2” thickness, given the reciprocating action. FWIW jigsaw is not what most people would consider “by hand.”
chughes10
4 posts in 613 days
#7 posted 11-16-2016 05:56 PM
No, it isn’t by hand but that was my next step after the hand saw gave me horrible results. And I went as slowly as I could. Part of the issue is that the thickness of the wood made it nearly impossible to get the blade to pass through the end, and going slower caused the wood to burn. The cut end is black from the heat.
- gargey
View Redoak49's profile
Redoak49
3342 posts in 2045 days
#8 posted 11-16-2016 06:06 PM
I have two band saws. One is a 16” Jet I use mainly to resaw. The other is a 10” Rikon for small stuff. With the right blade, the 10” Rikon does very well.
The big thing for you is to try to figure what kind of projects you want to do…base a bandsaw on the projects you want to do.
gargey
#9 posted 11-16-2016 06:14 PM
Hmm. You should look into getting a bandsaw.
No, it isn t by hand but that was my next step after the hand saw gave me horrible results. And I went as slowly as I could. Part of the issue is that the thickness of the wood made it nearly impossible to get the blade to pass through the end, and going slower caused the wood to burn. The cut end is black from the heat.
- chughes10
chughes10
4 posts in 613 days
#10 posted 11-16-2016 06:30 PM
Well to put it in perspective, I am into archery and DIY projects. I am shaping a crossbow stock. I am using the butternut because I haven’t got to worry about it splintering or shattering, but it’s much lighter than oak. I do a lot of weaponry projects that require a combination of wood and PVC. This particular project has made me realize that investing in some more serious equipment is going to make my life a lot easier down the road.
- Redoak49
View LittleShaver's profile
LittleShaver
339 posts in 675 days
#11 posted 11-16-2016 06:45 PM
I have a 14” Grizzly that I found on Craig’s list a few years ago for about $200. Does everything I want it to do. I did buy some good blades, which helped. It can only re-saw 6”, but it handled re-sawing 6” white oak like a champ this past weekend. Listen to the saw and don’t push it too hard and it does fine.
My only modifications were to add a speed tensioning crank and zero clearance inserts. Whatever saw you get, the speed tensioning crank is worth the upgrade. I’m a hobbyist, so I change blades for almost every new project. The tensioning crank makes this a snap, rather than a knuckle busting chore.
-- Sawdust Maker
