Kreg tables
Forum topic by Woodchuck2010 posted 11-16-2016 02:43 AM 974 views 0 times favorited 15 replies Add to Favorites Watch
View Woodchuck2010's profile
Woodchuck2010
721 posts in 1006 days
11-16-2016 02:43 AM
I went for the 2 for 1 Kreg table deal. Very nice and sturdy tables! Quality Kreg stuff of course. I decided to use one for my out feed table. It’s much stronger than what I had made before. I’m very impressed. I’ll probably make a cabinet in it also.
-- Chuck, Michigan,
15 replies so far
View Heywood's profile
Heywood
46 posts in 1596 days
#1 posted 11-16-2016 04:18 AM
Who did you get them through? I dig Kreg products
Woodchuck2010
#2 posted 11-16-2016 04:48 AM
Peachtree woodworking supply. I like Kreg too. I have a few of their products. All great stuff.
-- Chuck, Michigan,
View helluvawreck's profile
helluvawreck
32083 posts in 3015 days
#3 posted 11-16-2016 08:03 PM
These are very nice and can be used for a variety of purposes. They’re good quality and will make a nice addition to your shop.
helluvawreck aka Charles
Heywood
#4 posted 11-16-2016 10:38 PM
Thanks Chuck
View greenacres2's profile
greenacres2
328 posts in 2316 days
#5 posted 11-17-2016 01:41 AM
I got a pair from Peachtree as well, along with 4 sets of their casters—at $10 a wheel they’re less than the red phenolic plate casters I usually get, and really nice. Am in the midst of a table build, so once I assembled the stands, I screwed 3 8 foot 1×4’s to them to tie them together, threw a sheet of OSB on top of that, and proceeded to lay out the 5” wide boards for a 40” x 106” table top. Rolls around unbelievably easy. Timing was perfect for much needed temporary space.
My more permanent thought is to use one for an outfeed for TS, set another to the height of my RAS on the left side. There are so many ways they could be used, I may try to keep the top surface (whatever I end up doing) kind of easy to change/remove. Nice stuff.
earl
Woodchuck2010
#6 posted 11-17-2016 02:39 AM
I got a pair from Peachtree as well, along with 4 sets of their casters—at $10 a wheel they re less than the red phenolic plate casters I usually get, and really nice. Am in the midst of a table build, so once I assembled the stands, I screwed 3 8 foot 1×4 s to them to tie them together, threw a sheet of OSB on top of that, and proceeded to lay out the 5” wide boards for a 40” x 106” table top. Rolls around unbelievably easy. Timing was perfect for much needed temporary space.
earl
- greenacres2
Awesome idea. I do love the versatility.
-- Chuck, Michigan,
Woodchuck2010
#7 posted 11-17-2016 02:39 AM
Thanks Chuck
- Heywood
No problem Heywood!
-- Chuck, Michigan,
Woodchuck2010
#8 posted 11-21-2016 10:40 PM
I’ve started enclosing the stand. I just need to make a couple of doors now.
-- Chuck, Michigan,
greenacres2
#9 posted 11-22-2016 03:09 AM
These came at the right time. 2 Kreg stands with casters, strung together with 3 1×6’s. Table top glue up, 112” x 40” x 1 1/2” thick. Dozen pipe clamps and 3 sets of cauls. Wheels locked and it didn’t move a bit. Unlock them and it moves any direction with one hand. This was a blessing yesterday!!
earl
Woodchuck2010
#10 posted 11-22-2016 01:52 PM
These came at the right time. 2 Kreg stands with casters, strung together with 3 1×6 s. Table top glue up, 112” x 40” x 1 1/2” thick. Dozen pipe clamps and 3 sets of cauls. Wheels locked and it didn t move a bit. Unlock them and it moves any direction with one hand. This was a blessing yesterday!!
earl
- greenacres2
Great job! I like it!
-- Chuck, Michigan,
greenacres2
#11 posted 11-23-2016 02:32 AM
Thanks Chuck. I like the look of the enclosure, and will consider it. One of my stands will get the Kreg assembly top that is on the end of my work bench now. But…during the course of this table build, I’ve clamped si many parts to the 1 by’s that I may keep one open just for that use. When routing the spline grooves, a pair of quick clamps held each board in place—quick change. And another pair of clamps held a plywood scrap that served as a place to set the router. After routing the first one—and having the cord and hose get hung up—I flipped the plywood clamps so the beams pointed up and served to guide the hose and cord.
earl
Woodchuck2010
#12 posted 11-23-2016 02:48 AM
I think a large lower shelf would be excellent and really tie the two tables together while giving you a ton of storage space.
-- Chuck, Michigan,
Woodchuck2010
#13 posted 11-24-2016 07:01 PM
Made the doors. Just have to put some poly on it.
-- Chuck, Michigan,
greenacres2
#14 posted 11-25-2016 02:09 AM
Looks good Chuck.
earl
Woodchuck2010
#15 posted 11-30-2016 08:12 PM
The 2 for 1 deal is still on from Peachtree woodworking. Its good through tonight. Grab ‘em while you can.
-- Chuck, Michigan,
