Stanley 602 cleaning finished
« back to Hand Tools forum
Forum topic by Marn64 posted 11-15-2016 10:47 PM 569 views 0 times favorited 7 replies Add to Favorites Watch
View Marn64's profile
Marn64
295 posts in 837 days
11-15-2016 10:47 PM
Topic tags/keywords: plane refurbishing
Hey everybody,
I did it! I finally finished cleaning off that bedrock 602 type 3 that I bought a while back. Here it is. All of the active rust on the body and parts has been removed leaving behind patina, the only remaining spot of rust is on the lateral adjuster, which is somewhat pitted. I still don’t know what to do about that, perhaps suspending only the lateral in citric acid? The plane has at least 85 + percent japanning still on it. I used brasso to polish the brass, and let it sit for about a month so that it can bring itself to a subdued antique brass color.
-- Benjamin, Milwaukee
7 replies so far
5013 posts in 2545 days
#1 posted 11-16-2016 11:49 AM
Nice!, and I’m still envious of the deal you fell into with that plane.
View dddddmorgan's profile
dddddmorgan
87 posts in 1180 days
#2 posted 11-16-2016 01:15 PM
That’s a bottle of ‘awesome sauce’!
Maybe a bit of Evapo Rust on a qtip? I’ve done this before with something similar when I wanted to preserve existing finish. Just get the qtip wet and dab it on and let it sit.
It’s time consuming and tedious but it will stop future rust and keep everything looking original.
-- Maintenance Man - I do precision guesswork based on unreliable data from people of questionable knowledge...
View HokieKen's profile
HokieKen
5570 posts in 1190 days
#3 posted 11-16-2016 02:07 PM
Nice work Benjamin! I agree with Dan^ Brush or rag a little of your citric acid onto the lateral lever.
-- Kenny, SW VA, Go Hokies!!!
Marn64
#4 posted 11-16-2016 02:17 PM
- HokieKen
Do you think that would be enough? Its pretty pitted.
View Don W's profile
Don W
18788 posts in 2619 days
#5 posted 11-17-2016 01:20 AM
Personally I’d use a wire wheel to clean the rust off the lateral adjuster. Use a piece of sheet metal to protect the japanned parts if you need to.
Or just oil it once in a while and rub it with a cloth. It’ll turn into patina.
View JayT's profile
JayT
5709 posts in 2263 days
#6 posted 11-17-2016 03:50 AM
Looking good. For the lateral, I’d use a wire brush on a Dremel and get it taken care of. You should be able to control the Dremel well enough to limit how much the wire brush touches. On a part that small, Don’s advice about oiling it to get a patina’d look back should work great. I wouldn’t want to do that on a whole plane, but would feel comfortable doing it for that one small spot.
HokieKen
#7 posted 11-17-2016 04:16 AM
- HokieKen
- Marn64
I’ve never used citric acid so I can’t really say. I use phosphoric acid and it would do the job. Don and JayT are probably right. I’m just a lot lazier than they are ;-p
