What does this jointer need?
Forum topic by firefighterontheside posted 11-15-2016 01:17 AM 848 views 0 times favorited 12 replies Add to Favorites Watch
18354 posts in 1885 days
11-15-2016 01:17 AM
I found this jointer on CL. It’s hard to tell what is broken from the picture, but I’m guessing it needs a new cutter head and not just knives as the ad suggests. What do you see? Thanks.
https://stlouis.craigslist.org/tls/5875950955.html
12 replies so far
View NormG's profile
NormG
6156 posts in 3033 days
#1 posted 11-15-2016 01:29 AM
That is a pretty big missing section. I think just the knives need to be replaced, the head unless something is broken should be ok
-- Norman - I never never make a mistake, I just change the design.
View mahdee's profile
mahdee
3898 posts in 1796 days
#2 posted 11-15-2016 01:31 AM
Yes, probably 3 knives. I would check the ball bearings under load.
-- earthartandfoods.com
View Aj2's profile
Aj2
1444 posts in 1827 days
#3 posted 11-15-2016 01:34 AM
Looks like something funny going on with the fhip breaker.
It looks looks like it’s separated from the knife.
Maybe it’s bent?Or not installed right
A new one from grizzly couldn’t be much more.
If it’s slim Pickens around your area I sure wouldn’t want to be in your shoes.:)
Aj
-- Aj
View Loren's profile
10476 posts in 3677 days
#4 posted 11-15-2016 01:36 AM
Looks like they hit some metal. New knives are cheap.
It takes more than hitting some nails to ruin a
cutterhead.
You’ll want to check the gib strips to make sure they
weren’t bent by the accident. Those are the strips
backed up to the knives by the gibs screws.
#5 posted 11-15-2016 02:00 AM
Thanks guys. I saw this and was just thinking about it, but wanted to be sure about the damage.
View Jerry's profile
Jerry
2658 posts in 1677 days
#6 posted 11-15-2016 02:19 AM
Even if you had to buy a new cutter head that is a steal. Does it come with it’s own moving crane ;-)
-- There are good ships and there are wood ships, the ships that sail the sea, but the best ships are friendships and may they always be. http://www.geraldlhunsucker.com/
#7 posted 11-15-2016 02:20 AM
It seems like a good deal, but I really don’t need it.
View bigblockyeti's profile
bigblockyeti
5140 posts in 1749 days
#8 posted 11-15-2016 02:42 AM
The knifes are the last thing touching the cutterhead and it doesn’t look like anything in front of them was damaged so very likely, a new set of knives and it would be ready to go.
View jwisbey's profile
jwisbey
35 posts in 2442 days
#9 posted 11-15-2016 03:15 AM
I have the same exact planer and just replaced the straight knives with a helical head. If you buy the planer and need the head/knives, PM me if interested.
View greenacres2's profile
greenacres2
324 posts in 2197 days
#10 posted 11-15-2016 03:16 AM
Let’s assume it’s a G1018. New G0656 (similar) is $825, plus shipping or a drive to pick up, when they come back in stock. I’d find it tough to pay more than half or the current retail and would shoot for less. If I could get it at $350 to $400, and find the cutterhead (discontinued) to be out of balance or damaged…Byrd or Grizzly helical is $400 plus bearings. Manufacture date has to be after 1992 I think for the helical heads to fit.
If it was me, i’d agonize a while, then decide to call 4 minutes after somebody else drove away with it for $300. ;>)
earl
View artsyfartsy's profile
artsyfartsy
987 posts in 1187 days
#11 posted 11-15-2016 04:22 AM
That’s a toughy! I’m not too good at mechanical on something like this. But, I have to agree with Earl at Greenacres2. If you could get the price down, it may be worth the trouble if there was any. You know me, I like a good deal just in case I need to repair stuff. Good Luck FF Bill.
-- DWelch. Michigan, The only dumb question is the one not asked!
#12 posted 11-15-2016 02:05 PM
Thanks for that offer jwisbey.
I definitely wouldn’t expect to pay the asking price. It’s a little high, but would expect to get it down to a good price.
I know what you mean Earl. BTDT.
Thanks for all replies. It means a lot that you all took the time to open the ad and take a look for me.
